2004 Grand Cherokee Limited - JeepForum.com
 2Likes
  • 2 Post By Bobo04
post #1 of 4 Old 02-05-2020, 05:32 PM Thread Starter
Bobo04
For sale 2004 Jeep Grand Cherokee Limited with 212k
I have owned this vehicle since brand new, at that time I was certified Chrysler tech ( 1997-2007) and I was the only person who did maintenance and repairs on this vehicle past and present. This Jeep had all 30k services performed religiously with Mopar parts and only Mobil1 oil was used for oil changes. I planned to keep this vehicle for many more years and in order to achieve that in last 10 months I have replaced many old wearable parts but wife purchase new car so Jeep must go.
List of parts which I replaced:
New front (upper and lower) control arms, rear lower control arms and upper arm ball joint. Upper arm has already been replaced.
New spring upper and lower insulators
New suspension bump stops front and rear
New sway bar links and bushings front and rear
New front diff bushings
New front axle perches
New Bilstein front and rear shocks
New front and rear drilled rotors and pads, also parking brake shoes
New blend doors in heater case, also replaced all insulating foam strips (factory installed ones turn into dust really quick) between vents and dash to eliminate loss of cold/hot air.
New harnesses in all doors (known problem).
New headlights and fog lights.
Engine bay:
New Mopar head gaskets, heads sent to machine shop and checked for
cracks, warping and milled.
During head assembly I replaced valve seals, lap the valves, install all new studs and bolts for exhaust manifolds and for head installation.
New hydraulic valve lash adjusters.
New timing chains, guides and tensioners.
All gaskets and "O" rings have been replaced on intake manifold, manifold cleaned internally.
Valve cover gaskets, stud and bolt grommets have been replaced with silicone units.
New spark plugs
Front cover gasket has been replaced including front crank seal.
New water pump.
New thermostat and housing.
New radiator and hoses.
New hydraulic fan pressure hoses.
5k miles old Firestone Destination A/T
I am probably missing something but as you can see this vehicle has been taken care off and EVERYTHING in this car is working. Interior is in great shape, there is some surface cracking on lether seats which is expected but there are no holes whatsoever. This Jeep is my daily driver so mileage will go up slightly.
I will include set of almost new Jeep wheels and all the spare parts that I have such as: Mopar diff fluid, Mopar 247 t-case fluid, rear axle bearings, seals, retainers, heated seats elements, steering wheel, seat frame with motors...and a lot more.
$3900 with all the spares.
Vehicle is located in Annapolis MD.
Thanks.
Bobo04 is offline
post #2 of 4 Old 02-05-2020, 05:35 PM Thread Starter
Bobo04
...I can be contacted for pictures and any other info at [email protected]
Bobo04 is offline
post #3 of 4 Old 02-05-2020, 05:42 PM Thread Starter
Bobo04
Some pictures...
20200203_161234_1580949520999.jpg   20200203_161127_1580949538976.jpg   20200203_161223_1580949560859.jpg   20200203_161207_1580949575593.jpg   20200203_161136_1580949591616.jpg
20200203_161042_1580949606728.jpg   20200202_105254_1580949654558.jpg   20200202_105221_1580949703021.jpg   20200202_105419_1580949727180.jpg
willis36 and Raffish like this.
Bobo04 is offline
post #4 of 4 Old 04-01-2020, 08:14 AM Thread Starter
Bobo04
Sold
Bobo04 is offline
You may not post new threads
