2000 XJ Cherokee in PA - JeepForum.com
post #1 of 1 Old 11-23-2019, 11:05 AM Thread Starter
Paul_C
109k miles. Never in an accident. General Grabber AT2 tires 4 years old 12k miles on them. Duralast battery 2 years old. Newer windshield, muffler, front brakes, shocks, sway bar bushings, freeze plugs, electric fan. Still has original 0331 head and it's not cracked.
3rd owner. I purchased around 04. 2nd owner only had it a few months. A few years later I replaced the 231 transfer case with a 242 including shift gate, harness and bezel. The original low mileage 231 and parts are included. I also installed an overhead console, factory fog lights and fast idle switch. Avitel remote start and XM docking station. Will fit the Onyx EZ, maybe others.
AC does NOT work. Evaporator sprung a leak about 5 years ago. Drivers side headlight bezel is broken. Electric door locks are intermittent (door harness). New PA inspection, but the original rear drum brakes barely passed. Also has an evap emissions code. It's been passing PA emissions exempt for low mileage (less than 5k)
It's still in good shape. Basically for the last 5 years it's been my winter driver / home depot hauler. I just got a new KL and was going to keep the XJ through the winter. Would make a great project. Asking $2000. Located at 19067.
Paul_C is offline
You may not post new threads
