1994 YJ with lots of goodies - JeepForum.com
post #1 of 2 Old 06-26-2019, 01:47 AM Thread Starter
mike_breaker_5
mike_breaker_5's Avatar
Like it says. 1994 YJ for sale.
1978 ford snow fighter high pinion front d60 4:88 and original manual locking hubs.
1968 military power wagon rear full float d60 with disk conversion and 4:88
Tucked belly.
Brand new throttle down kustoms frame.
Skyjacker anti wrap setup on rear axle.
Brand new Smitybuilt rear bumper and tire carrier arm.
Brand new Smittybuilt rock sliders.
OD green monstaliner outside.
Black monstaliner inside and underneath.
Tired 5.2 magnum mpfi.
2- AX-15's, one good (loose input bearing) one not so good (3rd gear syncros out).
231D x-case with upgraded chain and crown SYE kit. And enough parts to build another and a half x-cases.
Block hugger exhaust to single 2.5" flow master 40 series muffler and out the back.
Set of long tube pace setter headers included.
1.5" Rubicon Express heavy duty lift, spring over leaf springs.
Custom shock hoops up front with bilstein 5150 front and bilstein 5100 rear shocks.
No sway bars.
No trac bars.
Custom HD steering setup:
Full crossover hi-steer with Chevy 1 ton tie rod ends. All weld-in threaded inserts for tie rod ends into Dom tubing.
Hydraulic hand e-brake.
Hard top and like 90% of everything for the soft top.
Hard full CJ7 full doors included (could use some tlc).
Half doors pictured.
37x12.5x16.5 hmmwv 12 bolt wheels and tires (70% tread).
Metalcloak hi arch front fenders with 4" flare.
TJ cut rear columbia/Rubicon flares.(from Hendrix and dumpster dive)
Rear drivers side corner damage from stump.
Windshield spiderwebbed on pass side.
Some minor rust starting on and around rocker areas.
I think I have a chipped rear pinion.
Drivers rear outer axle seal bad.
Diff breathers need installed.
Trans cover needs reinstalled.
It runs and drives. I have a 550hp mopar 440bb with standalone efi and a 900hp capable 727tf to put in it if intrested. I will be listing the motor and trans separately but more than willing to make a package deal if you drive away with it all.
After ratmonkey passed (my RL bestie since kindergarten) I lost my drive to keep building it. It hasn't been used and abused like it deserves.
I think my build is in my signature. Go check it out. I'm sure I'm missing a few things. I would love to get $10k out of this thing... I have over double that in the jeep alone. But I'd sell her for the best reasonable offer. She was built with hate, yuengling, nicotine, and a bunch of swearing.
Ratmonkey donation page. all proceeds will go to his family.
it's not much to look at... but it's mine.
5.2lswap, metalcloaks, bedliner, tucked belly, d60's, soon to be nv4500 and d300.
mike_breaker_5 is offline
post #2 of 2 Old 06-26-2019, 01:54 AM Thread Starter
mike_breaker_5
Military '94 yj, now with more 'tons and hummer junk.️ https://www.jeepforum.com/forum/f22/military-94-yj-now-more-tons-hummer-junk-990191/
There is the build page if it isnt anywhere else
You may not post new threads
