1981 Jeep CJ-5 w/ AMC 304 V8 - JeepForum.com
View Poll Results: Price?
Too High 3 75.00%
Too Low 1 25.00%
Just Right 0 0%
Voters: 4. You may not vote on this poll
post #1 of 1 Old 03-07-2020, 09:34 PM Thread Starter
boiseskibum
Newbie
Selling my 1981 Jeep CJ5 4x4 with AMC 304 V8 engine. $8,400
Engine was completely rebuilt by an engine shop at the Las Vegas Motor Speedway and has less than 50 miles on it!
Upgrades:
  • Tom Woods Custom Driveshaft
  • Painless Performance Wiring Harness
  • Pro Comp Rear Bumper
  • Warn Front Bumper
  • Warn M25314 Winch
  • Davis Unified Ignition (DUI) Distributor
  • Rough Country 4” Suspension Lift
  • Re-Geared 4.10 Ratio
  • POR-15 coated frame, engine, transmission, transfer case, and axle housings
  • Sport Cage
  • Heavy-Duty Cast Iron Rear Differential Cover
  • Upgraded One-Piece Rear Axles
  • Polyurethane Suspension Bushings and Body Mounts
  • Quick-Disconnect Sway Bar
  • Best Top Seats & Seat Slider
  • Bikini Top
  • Edelbrock Valve Covers
  • Edelbrock Performer Intake Manifold
  • New Tail Lights
  • New Headlights
  • New Stainless Steel Brake Lines
  • New Wheel Bearings
  • New Power Steering Pump
  • New Brake Master Cylinder
  • New Battery
  • New Windshield
  • New Clutch
  • New Starter
gotpropane.com Propane Conversion Kit
Jeep currently runs on forklift propane tanks, making it emissions exempt! The pressurized propane system acts like a fuel injected engine; no worrying about stalling or gasoline spilling out of the carburetor at steep inclines—this engine would run upside-down if you let it. This could easily be converted back to gasoline with the addition of a fuel tank and carburetor.
Call Chris at 208 – seven seven nine - 2024
boiseskibum is offline
You may not post new threads
