Wheel size help - JeepForum.com
post #1 of 4 Old 12-23-2017, 02:48 PM Thread Starter
cthusker174
Wheel size help
I want to put these wheels on my 1999 TJ Wrangler. I realize it will require spacers but wanted to know if these will in fact fit with the proper spacers? Any help is much appreciated....
Jeep JK Wrangler OEM Wheel Size: 17"
Lug Pattern Metric: 5x127mm
Lug Pattern Inches: 5x5in
Stud Size: 1/2x20
Hub/Center Bore: 71.5
What would be a good tire size for these wheels? Going to replace the tires shown if the wheels can fit my TJ. Jeep is not lifted and very seldom goes off road.....
Screen Shot 2017-12-23 at 4.35.42 PM.jpg   Screen Shot 2017-12-23 at 4.34.03 PM.jpg
cthusker174 is offline
post #2 of 4 Old 12-23-2017, 06:42 PM Thread Starter
cthusker174
Originally Posted by TrailBadger View Post
Jeep TJ Wrangler OEM Wheel Size: 17'' x 8"
Lug Pattern Metric: 5x114.3 (one would need a 5x114.3mm to 5x127mm wheel adapter)
Lug Pattern Inches: 5x4.5in
Stud Size: 1/2" - 20 UNF
Offset / ET: 20 - 25.4 (the above JK wheel's Offset / ET on the 17'' x 7.5 is 44 check inside the wheels for a mold mark "ET44" etc)
I'm buying these from someone so I'll try and see if they can get me the mold mark? I don't know what ET really means as I've never messed with something like this conversation. However these are the adapters that I think would work? BTW thanks for the info you've provided me... I'm getting ALL the wheels for a 100 bucks. Tires aren't worth saving but I figure the wheels should be worth that much? Your help is greatly appreciated...
post #3 of 4 Old 12-23-2017, 07:21 PM Thread Starter
cthusker174
Would these be the right adapters to use? Trying to get the ET for these wheels as you suggested. I'm buying all 4 wheels for 100 bucks which seems to be a decent deal.... Thanks again for the guidance
4 Brand New Black Hub Centric Jeep 5x4.5 to 5x5 (5x114.3mm to 5x127mm) Wheel Adapters | COMPLETE BOLT-ON KIT | CHANGES BOLT PATTERN |
Wheel Adapter Specifications: Color: Black | Thickness: 31mm(1.25") | Bolt Pattern: 5x114.3mm (5x4.5) | Wheel Bolt Pattern: 5x127mm (5x5")| Center Bore: 71.5 | Thread Pitch: 1/2" | Material: Aerospace 6061 T6 Forged Aluminum
Hub Centric = The correct way to space out your wheels. Our spacers fit perfectly over your vehicles hub, which eliminates any possibility of vibrations at high speeds. Perfect for fixing clearance issues, for example; your wheels hitting shocks/struts or brake calipers
Gives your vehicle an aggressive stance & allows for better handling characteristics. We have tested these adapters in aggressive offroad and have withstand every single time.
These adapters allow you to adapt 2007-2016 Jeep JK XK WK Wheels (5x5) to older Jeeps YJ TJ KK SJ MJ (5x4.5"). We also carry 1.25", 1.5", 2", 2.5" & 3" Thickness. Made In The USA
post #4 of 4 Old 12-24-2017, 09:45 AM Thread Starter
cthusker174
Thanks... and I'm for sure going to check everything several times before purchasing the adapters!
