Two Blown BFGs - JeepForum.com
post #1 of 14 Old 01-29-2013, 09:49 AM Thread Starter
D328jet
Two Blown BFGs
Hi Everyone,
I won't say this is a unique question, this being a Jeep site and all, but unfortunately I need some advice/perspective. Here's the story...
Blew two tires to start the day on a snow covered drain foundation adjacent to an access road at Snowshoe, WV. Don't try this at home folks. I tore the tread completely cross the tire on one and the other had a slow leak. I used the spare and Snowshoe maintenance used three plugs to plug one successfully for 25 miles before it blew as we happened upon a closed gas station after backtracking on a flat tire for 3 miles at 3 MPH in BFE. Someone knew someone who knew someone, and we had a used tire for $20 installed to get us back to DC. This guy will be getting OMAHA steaks on his front door step. For all the crap WV gets, ya gotta love em.
So, as a result of this, I've heard about 2 ply vs 10 ply tires and am debating just replacing the two that blew with stock, or getting 5 new 10 ply (possibly 33s or 35s). It's a 2012 MW3 stock daily driver and gets light to medium trail use. I don't plan on running over these drains again, but I would at some point like to go 2.5-3 lift and 35s. Granted that's close to a $2800 investment at this point minus selling the almost new three good stock tires.
Any thoughts on this?
D328jet is offline
post #2 of 14 Old 01-29-2013, 09:59 AM
Spike6901
I run E rated BFG AT's and have never had a flat, not once and the sidewalls are scored up from rocks that have gotten through at least one ply.
They ride a little more rough but are hell for stout.
'14 WK2: Armor, Dog Taxi
'17 JKU: Lift, Armor, more...
'97 ZJ: Lift, exhaust, more...
Spike6901 is offline
post #3 of 14 Old 01-29-2013, 10:14 AM Thread Starter
D328jet
What size? I can't find a stock size in an E rating.
D328jet is offline
post #4 of 14 Old 01-29-2013, 10:18 AM
TheBoss
TheBoss's Avatar
This was kind of a unique curcumstance though don't you think. Sure the e rated 10 ply will be a bit tougher but also heavier and you'll be running half of max air pressure in it to get it to ride and wear correctly. Maybe look at the Goodyear with Kevlar brands such as the Silentarmor or MTR. What model BFG was this that failed on you?
TheBoss is offline
post #5 of 14 Old 01-29-2013, 10:26 AM Thread Starter
D328jet
BFGoodrichMud-Terrain T/A KM (stock on '12 MW3/Rubicons? 255-75-17). They are C rated.
Hmmm, yes and no. I was going about 20-25 MPH and the concrete had a sharp edge, not unlike a rock in some instances, but you're right, I wouldn't be rock climbing at 25 MPH. If I'm getting into heavier trail stuff, I wasn't sure if a basically "road tire" would stand the abuse.
D328jet is offline
post #6 of 14 Old 01-29-2013, 10:41 AM
tslewisz
2010 JK Wrangler
Well, my first thought is that what most people call "10-ply tires" don't really have 10 plies any more. That term comes from bias ply days and most of us run radials. We roughly equate it to E-rated, which really only means that the tire is built to handle 80 PSI, which is nice when towing or hauling heavy for stability. They are typically tough, but they're also heavy and don't ride very well in a light-ish Jeep. If we're talking about a heavily armored JKU with D60's that goes close to 4 tons, that's a different matter.
My BFG 315 carcasses (I have TreadWright re-treads) are D-rated, have a 3 ply sidewall, and 28 PSI gives a decent ride on road while 14 PSI works fine off road. My Jeep is probably on the light weight end of the scale.
tslewisz is offline
post #7 of 14 Old 01-29-2013, 10:42 AM
GPV
Load range E max pressure is 80 psi not only will it ride rough you will wear the center of the treads out very quickly. Load tangent C tires are fine, even for wheeling, in fact aired down the C tires will function better then E rated tires since they will flex. Has anyone looked at the failed tires?
Sean
2008 Jeep JK Rubicon Unlimited (Bought for Wife)
2007 GMC 2500HD Duramax (Work Horse)
1982 Honda CB 900F Supersport
2001 Honda RC51
GPV is offline
post #8 of 14 Old 01-29-2013, 10:48 AM
RubiconTested
RubiconTested's Avatar
With all due respect,
I've been lucky to grow up in the off-roading and desert racing world, and spend a lot of time with my dads friends at BFG, General, Goodyear, Maxxis and Falken and there is a term I hear a lot.
"Where those tires the victim or culprit?"
The tires you have are tried and true - possibly the most used light truck mud tire ever. You should be fine using them again.
Austin
RubiconTested is offline
post #9 of 14 Old 01-29-2013, 10:48 AM
TheBoss
TheBoss's Avatar
They test the BFG's on the Rubicon so I would guess they hold up ok,but I have heard of the KM & KM 2's have a somewhat tender sidewall. I guess it really depends on wheel placement on the trail. I had my Silentarmors through some really sharp rock out in Arizona with no issues. I wouldn't mind having these in a 35 because they are such a great all around tire,but they only size them up to a 285/70/17. Personally I think my next will be the MTR in a 35. I think a load range d would be the max for a 4dr c for the 2dr.
TheBoss is offline
post #10 of 14 Old 01-29-2013, 10:49 AM Thread Starter
D328jet
The tire I had switched to get us to DC is back at their shop. The one that I ripped clear across is on my spare rack on the back. I'll have the shop look at it and see if there's anything to be done with BFG. You're right, I should have kept that other one but it only had a relatively small opening just shy of the sidewall. I do however have a picture of it after plugging.
D328jet is offline
post #11 of 14 Old 01-29-2013, 11:05 AM
Demp
Originally Posted by TheBoss View Post
They test the BFG's on the Rubicon so I would guess they hold up ok,but I have heard of the KM & KM 2's have a somewhat tender sidewall. I guess it really depends on wheel placement on the trail...
I've heard the same from those in my rocky places, and many opt for the MTR or Silentarmor for their kevlar sidewalls.
Personally never had an issue with KM and KM2 but where I live is mostly sand, mud, and water
Demp is offline
post #12 of 14 Old 01-30-2013, 12:00 AM
jfive
jfive's Avatar
I've got over 30k miles on a set of E load tires on my JKU and they wear evenly and ride smooth (Toyo MT). Not accurate. Inflate them properly and keep them aligned.
Cheers,
John
'11 JKU
'88 YJ
jfive is offline
post #13 of 14 Old 01-30-2013, 09:30 AM
222Doc
222Doc's Avatar
The trouble we have here in AZ. in the end. cactus spines..... They wont get you right away but after a few years on the trail they work in and you get that slow leak, cactus style. even the MTRk's. Nothing can stop these.
the rubicon is not to hard on tires. after this summer its not even that hard on a jeep. They filled and blasted the little sluice, big sluice and the tree tight spot was opened up. few year sback the blated the gate keeper.
I could run a stocker through it now. on street tires.
Dusy run! 013
222Doc is offline
post #14 of 14 Old 02-02-2013, 09:18 PM
GPV
You should get more than 30k! Having said that I got 50k out of the first set of BFG ATs I put on my truck and only 25k out of the next set. Not impressed with that at all. My truck is almost twice as heavy as the Jeep and then pulls a 10k load..................... I believe that the first set was a miracle fluke compound that wasn't ever meant to be sold to the public
Got 60k out of the original BFG MTs on the Jeep...................... 5 tire rotation.
Sean
2001 Honda RC51
GPV is offline
