trailer tires? - JeepForum.com
 1Likes
  • 1 Post By jbolty
post #1 of 9 Old 04-26-2021, 03:31 PM Thread Starter
jbolty
Administrator
jbolty's Avatar
trailer tires?
I have had a bunch of flats this season and I'm pretty sure it's because the tires are over loaded. They are only rated (I think) 1820#. have not weighed my jeep but guessing with the ton axles it has to be 5000 + the trailer itself sits maybe 1500 so pretty close to max constantly with firewood and other stuff.
Size is 205/75/15 but all the load E tires I can find are 225/75/15. I know it's only about an inch taller but there is already not a lot of room under the fender. .
any thoughts welcome on brands to buy or stay away from or who has a heavy rated 205 tire
thx
jbolty is offline
post #2 of 9 Old 04-26-2021, 03:58 PM
222Doc
222Doc's Avatar
tire is over weighted for sure. So that size you cant get an E. Wont matter if that is the case if over weight more over at speed since even ones rated at say 2500 each are still speed rated to around 75 max. The China ones are not reliable at all had have new ones not last a year . After Goodyear moved that division back here the tire is good had no issues in three year total on two seperat trails that started with China junk. But Corsair? is total junk dangerous even. We tow the jeep a lot i always use Discount since they are in the states we tow Cali, Utah, Nevada AZ and wheel. Even my 37 are Discount with Certs and fact is they tend to get replaced by warranty well before the reach tread being to low. Cut by rock covered, but fact is here they die from Cactus in the end if not by a rock anyway. You get leaks from Chollo cactus no side wall repairs so new tire. only pay the the next warranty cert 70 bucks for 450 dollar tire.
must be a small trailer i have a 16 foot its alloy too rated for 7k load and i bet it weighs 1500. my last one was all steel and was very heavy. Must have been over a ton. its about three years now old started with those China junk they always use. They started blowing out about a year.
222Doc is offline
post #3 of 9 Old 04-26-2021, 04:04 PM Thread Starter
jbolty
Administrator
jbolty's Avatar
thanks. my trailer is 16' steel but the narrow format and open in the middle so not overly heavy by itself.. Here in CA it's not legal to ever tow anything over 55 at any time. Of course people do but my RV uses way more gas at speed so I take the extra hour to get where I'm going.
jbolty is offline
post #4 of 9 Old 04-26-2021, 04:15 PM
Wheelin98TJ
JEEP FREAK
Wheelin98TJ's Avatar
Goodyear Endurance is highly recommended on a boat forum I am on.
I haven't used them, but they are the clear favorite amongst those guys.
The 205/70/15 load range D is rated for 2,149 lbs.
https://www.goodyear.com/en-US/tires...ng=-83.7305392
The 225/75/15 load range E is rated for 2,833 lbs.
Wheelin98TJ is offline
post #5 of 9 Old 04-27-2021, 11:52 AM
Fourtrail
1974 CJ6
you couldn't pay me to run a 205 on anything bigger than a lawmower trailer. Step up to the 225 even if it means cutting off and welding on new fenders, you will be money ahead in tire life. Trailer tires are a replace every 4 year item, that is all they are rated for due to UV deterioration.
80 CJ-5, 74 CJ-6, 56 CJ-5
Fourtrail is offline
post #6 of 9 Old 04-27-2021, 12:48 PM Thread Starter
jbolty
Administrator
jbolty's Avatar
Yup, I agree after all my reading. I should have plenty of room
thx
jbolty is offline
post #7 of 9 Old 04-27-2021, 06:24 PM
Fourtrail
1974 CJ6
Have been running Thunderer tires on 2 trailers and have had good luck for the 3 years they have been in use. Should make it to the 4 year mark before replacement is needed.
post #8 of 9 Old 05-04-2021, 09:26 AM Thread Starter
jbolty
Administrator
jbolty's Avatar
Got a set of endurance 225. The fender brace was already close so I moved them to be safe. Now need to find a couple rims for cheap spares since I destroyed two this year.
Wheelin98TJ likes this.
jbolty is offline
post #9 of 9 Old 05-04-2021, 09:33 AM
LouC
2007 WK
The only trailer tire from the far east I have heard consistently good things about is the Kenda Load Star. They are a bias ply tire and I think bias tires if you are buying from that part of the world are actually less risky because the technology required to manufacture a good steel radial tire is far more involved than a simple bias ply tire. Firestone found that out the hard way back in the 1970s with the 500 recall that nearly killed them.
https://specialty.kendatire.com/en-u...loadstar-k550/
these are reasonably priced and are available in a 225/75-15 size 10 ply rated to 2830 lbs each.
2017 JK Unlimited Sport 6 spd
2007 WK Limited Hemi QDII
1998 ZJ Laredo 4.0 Selectrac
LouC is offline
