ProComp MT2 vs GY MTR Kevlar vs Nitto Trail Grappler - JeepForum.com
post #1 of 6 Old 04-18-2019, 10:09 AM Thread Starter
Orannis
Hey guys, I'm getting to the point of needing new tires for my 99TJ, and was looking for some input/opinions/advice.
I've done quite a bit of looking around online and found lots useful, but sometimes contradictory info. Not that I imagine I'd get a 100% consensus here, but wanted to get my specific needs as part of the conversation.
Tire Size: 33x12.50R15
Load Range: C
Daily Driving: Limited commuting (I bike to work a lot).
Freeway: Limited (down right rare, even with 4.88 my 2.5l no joy on the freeway)
Wheeling: Drive to trails. AZ/Cali/Nevada/Utah. Generally desert, lots of sharp rocks. Go out wheeling/camping quite often.
Don't really care about winter handling since it's such a rare occurrence out in Tucson anyways.
Currently I'm running ProComp MT2's (on the Jeep since I lifted it). I have no complaints with these, never had a flat or sidewall puncture, have gripped well offroad, fairly quiet, and generally held up well over the 5 years I've had em. However, they are my only frame of reference.
From my research it seems that the MTR K's are either loved or hated pretty decisively. It seems that balancing issues are a concern, and therefore uneven wear could be a problem. They are also on the lighter side, especially compared to the Nitto Trail Grapplers. Some say that the sidewalls are tough, and others say they are tissue paper. Road manners seem positive, and offroad performance seems positive as well.
There's been a lot of positive posts about the Nittos. Downside seems to be that they are heavy, however, at my size and load range I'm not sure if thats an issue (haven't found a spec for weight for this size/load range). Most of the posts complaining about weight and stiff sidewalls were the D or E range tires. Some people mentioned an issue of radial drift.
That being said, a lot of these posts were from a few years ago, not sure if there have been any changes by the manufacturers.
Overall, just looking for some feedback by anyone who has run any of the tires.
Also open to other tires other than these 3.
Thanks in advance.
Orannis is offline
post #2 of 6 Old 04-20-2019, 06:55 AM
williambmac
williambmac's Avatar
the nittos weight 71.47 lbs each, more than my 35" baja mtz's
https://www.nittotire.com/light-truc...ht-truck-tire/
I ran GY MTR's with no luck. I know people love them, but I had balance/vibration issues with mine.
2005 Rubicon Unlimited, 4" Clayton long arm
35" Mickey Thompsons, lots of stuff
Black Magic Big brake kit
williambmac is offline
post #3 of 6 Old 04-20-2019, 07:39 AM
bbacus
bbacus's Avatar
There are a lot of good tires out there. I run Goodyear Fierce Attitude MT and love them. However you can only get an E rated tire. Buy what you like. Most MT tires are pretty good. It’s more a matter of personal taste. Good luck.
bbacus is offline
post #4 of 6 Old 04-20-2019, 03:29 PM
biffgnar
biffgnar's Avatar
I fall in the category of being a big fan of the MTRs. I believe early runs of the tires were much more prone to the balance issues than today. They do flat spot easily so best to be balanced when warmed up. With that caveat, my guy being careful and patient using a Hunter machine has never had a problem. I believe current set is my third set. Never had a side wall issue. They do get a little noisy as they wear. I still believe great multi-use tire. But they are multi-use. They do a lot of things well, but in any one area there are probably use specific tires that are better.
Nitto's are great tire IMO, but the weight has always dissuaded me. Not a problem on a high power 4400 car, but for my TJ I can't ignore it.
biffgnar is offline
post #5 of 6 Old 04-20-2019, 05:54 PM
222Doc
222Doc's Avatar
In Az the Mtrks are the most popular at least this part of it. I see a lot of tire damage with the amount of jeeps we run all winter here, and i will say FEW are the Mtrk's matter of fact i only know of one on a trail i was on or lead, can recall. The list of pro comp. bfg getting cut is long, here. Not that any tire can not be cut, it is mostly DRIVER.
the bad is the Mtrks are rather expensive.
Here in AZ the rock is rather sharp it tends to cut up side walls rather fast without care where you put the tires many on the moderately hard and up trails. Then there are these things that will end any tire made here in AZ. they will get you in the end. death by a thousand pricks.... once the get in a tire you can not remove it and it only travels in one directing so in time it just makes its way through. Try pulling one out of flesh.
222Doc is offline
post #6 of 6 Old 04-22-2019, 09:28 AM Thread Starter
Orannis
Thanks for the input! This is exactly the sort of stuff I was looking for. Appreciate the time taken to respond
Orannis is offline
$750_5 Nitto Trail Grappler M/Ts (33"/12.5/15) CP71270 Tires & Wheels 0 02-14-2019 03:01 PM
TWO - 35x12.5 R15 Mtr kevlar, soft 8, 5x5 pattern. 325$ robswampthing Tires & Wheels 0 02-13-2019 02:14 PM
Nitto All Terrain Grappler Tires ec2981 Tires & Wheels 2 12-20-2018 07:39 PM
Nitto Trail Grappler M/T 295/70r17, set of 5 RockScar Tires & Wheels 0 10-07-2018 07:22 AM
BRAND NEW Set of Nitto Trail Grapplers (315/75/16) with beadlock wheels Goliath-XJ Tires & Wheels 1 02-09-2018 08:20 PM
