Newbie trying to buy a wheel... - JeepForum.com
post #1 of 4 Old 03-22-2010, 08:33 PM Thread Starter
lopezzi
lopezzi's Avatar
1983 CJ7
So when I bought my Jeep CJ7 a while ago, it came with 33x12.5 R15 wheels on it. However, the spare on the back was the stock small tire and obviously would not work. I was able to buy a Mickey Thompson tire off a friend that is the same size, so now I need a rim. I have been looking at a rim on Quadratec (Black Rock Wheels 975585540 - Black Rock Series 975 Type Blade Steel Wheel in Matte Black for Jeep® Vehicles with 5x5.5 Bolt Pattern - Quadratec) but I don't know what size I need. From the research I have done, it seems like I can go with either an 15x8 or 15x10 but how do I know which one? I would think it has to match what is already on my Jeep, but I have no idea what that is. Is there a way to find out? Does it really have to match the others in case I need to use it?
1983 CJ7 258, Weber 34/34, Nuttered, Rushed, 4" Rancho Lift, 33" Bridgestone Duelers, 10k lbs Winch.
lopezzi is offline
post #2 of 4 Old 03-22-2010, 08:48 PM
AFjeepMan
AFjeepMan's Avatar
Well the best way to to measure across the wheel...it doesn't need to be exact, but you will be able to tell the difference between an 8" and 10" wheel with a tape measure and the help of a friend maybe.
2005 Wrangler TJ, 3 1/4" RC lift, Cragar Soft 8's 32" BFG Mud Terrains, Smittybilt SRC D-Ring bumpers, Smittybilt XRC8 winch, Body Armor Rockcrawler side guards
[_l_,[____],
l----L - OlllllllO-
(o)_) (o)_)--)_)
Wife≥Jeep>GF
Relearn your priorities.
WANTED: SYE and cv shaft...good condition and good price. for a TJ with about 5-6" of lift.
AFjeepMan is offline
post #3 of 4 Old 03-22-2010, 09:41 PM Thread Starter
lopezzi
lopezzi's Avatar
1983 CJ7
So how would I measure it? Do I go through the holes in the wheel from side to side? I did a preliminary measurement, but it looked like 12 inches so I'm not sure if I'm measuring correctly. If I did get a different size than what's on the Jeep currently, would it not work if I had to use it?
lopezzi is offline
post #4 of 4 Old 03-23-2010, 02:36 AM
AFjeepMan
AFjeepMan's Avatar
yes it would work, and I would put the tape measure through the holes in the wheel and measure flange to flange...that would be weird if it was a 12" wide wheel with a 12.50" tire...I doubt that this is the setup so maybe have your friend give you a hand and take a look...or go for it and order the 10" wide wheel because that is most likely what is currently being used.
[_l_,[____],
l----L - OlllllllO-
(o)_) (o)_)--)_)
Wife≥Jeep>GF
15x10 , 15x8 , 33x12.5 , 33x12.5 r15 , wheel width
4 wheel drive stuck in (Newbie) scubazufall Engines & Drivetrain 4 02-01-2009 03:43 PM
Wheel and tire fit question-very newbie HoosierJeepster Tires & Wheels 1 01-11-2009 10:29 AM
Newbie ... lift/wheel fitment question fuzzard Tires & Wheels 1 09-24-2005 10:14 AM
Newbie Tire and Wheel Combo Question... Tazman1717 Tires & Wheels 8 08-01-2005 08:38 PM
Newbie tire and wheel question mflave007 Tires & Wheels 3 10-19-2004 06:36 PM
