Max Tire Size for Stock TJ - JeepForum.com
post #1 of 5 Old 12-04-2005, 08:47 AM Thread Starter
R.T.
Wow, what a great site and great set of forums.
I am a newbie with a 3 week old 2006 SE, 4 banger (I'm sure you knew that) with the 6 speed manual trans. My jeep will spend 99% of it's time mall crawling and when I do take it off-road it will be on fire roads, open fields, etc, no rock crawling or mud bogging (I know you are thinking, what the hell is this guy doing here?)
I am not planning on doing any lift but I would like a more aggressive tire then the stock RT/S. Something that will help with a little mud, water, sand, etc. How big can I go and not get any rubbing or suck all the power out of the 2.4 ltr engine.
Thanks in advance,
RT
R.T. is offline
post #2 of 5 Old 12-04-2005, 08:51 AM
BlaineWasHere
BecauseRacecar
BlaineWasHere's Avatar
I would go with a 30x9.5 BFG AT or something like that... you could fit 31's but I would just stick with the 30x9.5 BFG AT's
2013 FR-S
BlaineWasHere is offline
post #3 of 5 Old 12-04-2005, 10:32 AM
JeepJohnson
Welcome! The biggest tire you can fit on a stock TJ would be a 31", I don't know how it would react though since they now put 3.73 gears in the 4 bangers . I have the 2.5L with LT235/75R15(29.1") Goodyear MT/Rs and it's just fine. For 99% street use this size would probably work out great.
JeepJohnson is offline
post #4 of 5 Old 12-04-2005, 11:23 AM
Dirty Backroads
Dirty Backroads's Avatar
Maybe you could find a set of OEM Ravine wheels with the 30"Goodyear GSA tires? Perhaps you can find just a set of Goodyear GSAs from someone who is lifting their new Jeep and going with bigger tires. A lot of people take them off and sell them and for what you want to do they would be perfect. I have 3.73 gears and these wheels/tires and they are fine. You can pick them up cheap. I wouldn't go any higher than 31s if I were you.
HERE is an example of what I'm talking about. Not sure if this includes the tires though. I would think so but the ad isn't clear. The Ravines w/GSAs works quite well on the street and even light offroad.
2005 Solar Yellow TJ Sport
Yellow Jeep Club Member #123
Originally Posted by Sniper111
Nothing like going topless with some Kid Rock blasting looking down on the rice boys with their dropped Civics wondering what Japanese steel would look like under the Mickey Thompsons.
Dirty Backroads is offline
post #5 of 5 Old 12-04-2005, 11:40 AM
RISNER
Guest
I'm running the 31/10.50's on my stock size wrangler. Its a 4.0L though, and I could tell a difference in the power and gas milage when I switched to them. A 31" is about as big as you can go and not rub while off-roading.... Hope this helps!
RISNER is offline
max tire size for a stock spare tire mount?? G-MANtj Tires & Wheels 11 05-13-2009 05:40 PM
Biggest size tire on stock rim with 5.5 BS? snakester14 Tires & Wheels 2 04-15-2009 03:55 PM
Stock Rubicon/Max Tire Size nomad_aviator Tires & Wheels 10 04-27-2006 06:35 PM
Max tire size on stock rubi yyoon Tires & Wheels 3 05-24-2005 07:13 AM
Tire size with the stock wheel? AggieTJ Tires & Wheels 14 05-15-2003 11:43 PM
