Looking for input on tire sizes - JeepForum.com
post #1 of 5 Old 02-07-2020, 05:09 PM Thread Starter
jmccann92
jmccann92's Avatar
Hello everyone,
I’m new to the Jeep world and I was looking for some input on tires. I currently have the factory 255/70/R18 size on my Jeep now and as I’ve been searching for some used tires it seems the 285/70/R17 is the most common size I come across. Some of the tires I’ve been looking at come with the rims. I was planning on getting the BF Goodrich KO2s I heard they handle pretty well in the snow. I’m just wondering if that size is going to work at all for my Jeep or if its going to be to tight. I don’t plan on doing any climbing but we do have rough trails in my area. I have a Wrangler unlimited Sahara at factory stock height. I plan on eventually doing a 2 inch lift.
Thanks for any suggestions!
jmccann92 is offline
post #2 of 5 Old 02-23-2020, 06:18 PM
Mrtoyou
Mrtoyou's Avatar
The 285/70R-17 is a very popular size and the KO2 is a nice all purpose tire. If you go with a 17" wheel just make sure they will clear the brakes.
If I have to explain it, you probably won't understand anyway!
Mrtoyou is offline
post #3 of 5 Old 02-26-2020, 12:14 PM
DiscountTire
Tire & Wheel Specialists
DiscountTire's Avatar
Originally Posted by jmccann92 View Post
Hello everyone,
Iím new to the Jeep world and I was looking for some input on tires. I currently have the factory 255/70/R18 size on my Jeep now and as Iíve been searching for some used tires it seems the 285/70/R17 is the most common size I come across. Some of the tires Iíve been looking at come with the rims. I was planning on getting the BF Goodrich KO2s I heard they handle pretty well in the snow. Iím just wondering if that size is going to work at all for my Jeep or if its going to be to tight. I donít plan on doing any climbing but we do have rough trails in my area. I have a Wrangler unlimited Sahara at factory stock height. I plan on eventually doing a 2 inch lift.
That would be a great tire choice. As Mrtoyou stated extremely popular and solid tire choice. Just to give you the dimensions. The 285/70R17 will be a hair over a 1/2 taller over all rolling diameter and 1 1/4" wider.
Check brake clearance but also if they are not stock wheels be aware of the offset as it will move depending on the new offset.
DiscountTire is offline
post #4 of 5 Old 02-26-2020, 05:10 PM
SkyjacktZJ
2010 JK Wrangler
You should be fine with a 2" lift. The other thing to consider is the offset of the wheels you are running. If you are running stock wheels you may need to add wheel spacers.
2015 JGC Altitude Edition
2010 Jeep Wrangler Unlimited Sport
SkyjacktZJ is offline
post #5 of 5 Old 02-27-2020, 08:44 AM Thread Starter
jmccann92
jmccann92's Avatar
Thank you everyone! I appreciate the info, I had found someone selling used ko2s on stock 2019 rubicon rims with spacers for $1000. Unfortunately it sold quickly, but it’s good to know I can make that size work. It seems like it’s the most common size
