Check my alignment specs - JeepForum.com
post #1 of 5 Old 10-02-2019, 02:17 PM Thread Starter
Spacewrangler*
Bought my Jeep brand new in 2018. Had it about 14 months now. Had a routine tire rotation and balance but they said one of my tires was wearing abnormally. They suggested an alignment. Can somebody please take a look at the specs and tell me if the numbers are correct or not?
Spacewrangler* is offline
post #2 of 5 Old 10-02-2019, 03:41 PM
Kruzin
Kruzin's Avatar
2009 JK Wrangler
You already have a thread about your alignment and tire wear, there is no need for another.
'09 JK Rubicon
'01 XJ Sport
'10 Fusion
Kruzin is offline
post #3 of 5 Old 10-05-2019, 12:49 PM
TRQ427
Front camber is "within tolerance" but not at preferred spec. You front toe in is also within tolerance,but on the positive side more than I'd want. Not sure if your camber is adjustable,but the toe is. Are you getting outside edge wear,,possible saw tooth wear of cupping? Those are all symptoms that may show from the readings I'm seeing. Camber closer to 0 would be better but most likely non adjustable,,and toe closer to total of .12 or so. All in all not to bad.. When were these alignment readings obtained? This is a print out from a Hunter alignment System,which is a top of the line machine for sure. Very good equipment being used.
TRQ427 is offline
post #4 of 5 Old 10-08-2019, 09:11 AM Thread Starter
Spacewrangler*
Interesting. So since the camber is currently not within the preferred specifications and not adjustable, and since I haven't done anything that would cause the alignment to be off, is it fair to assume that the Jeep left the factory/dealership with a camber setting that isn't at the preferred specifications? Is so, is that something that is typically covered by warranty?
Seems pretty ****ty that Jeep would sell somebody a brand new Wrangler with the camber not being in preferred specification, especially with no way to adjust it.
post #5 of 5 Old 10-08-2019, 09:15 AM Thread Starter
Spacewrangler*
EDIT
