Can I runs these rims on my TJ? - JeepForum.com
post #1 of 7 Old 02-15-2017, 07:57 AM Thread Starter
E46
I can't find a lot of info on if the offset will work but they're -44. I will be running them on 33s, 15x10.
https://www.summitracing.com/parts/p...165f/overview/
E46 is offline
post #2 of 7 Old 02-15-2017, 10:46 AM
biffgnar
biffgnar's Avatar
Will they bolt up? They are the correct bolt pattern. With 3.75" BS they are going to be set out fairly wide. Does NJ have tire coverage laws?
Whether the rest of your vehicle is able to run 33s is hard to say. You'll get better answers from people if you fill out your profile so people know what your setup looks like.
biffgnar is offline
post #3 of 7 Old 02-15-2017, 11:06 AM Thread Starter
E46
yea i just found someone who has done it. I don't know about the law but my friends have some pretty wide tires and they never got in any trouble for it. https://www.customwheeloffset.com/wh...-4-custom-rims looks pretty mean
E46 is offline
post #4 of 7 Old 02-15-2017, 02:32 PM
biffgnar
biffgnar's Avatar
If you are suggesting that is the lift you will buy, put the credit card down! That lift would be pretty close to the bottom of the list for most people. You need to go to TJ Tech and do some reading before spending any money.
biffgnar is offline
post #5 of 7 Old 02-15-2017, 02:36 PM Thread Starter
E46
I ordered the re 4 inch lift kit
E46 is offline
post #6 of 7 Old 02-15-2017, 04:59 PM
biffgnar
biffgnar's Avatar
A better choice than Skyjacker but still not one many around here would recommend. Serious recommendation is to go do some reading in TJ Tech and return the RE kit.
biffgnar is offline
post #7 of 7 Old 05-04-2017, 11:23 AM
Tomb Raider
Addicted...
Tomb Raider's Avatar
You can definitely run those wheels on your TJ. I ran them on my LJ with 35x12.50x15 BFG KM2s. You will have rub on the sway bar at full lock but otherwise, not a problem. You may not have the problem if your at 33's. I moved up to 37's that were 13.50 width and had to get 1.25" spacers with a -44 offset. Cheers !!
I like to build stuff. Want to know what I build, you can google it
Tomb Raider is offline
