Can I put 18" tires & rims on 20"? - JeepForum.com
 1Likes
  • 1 Post By mukluk
post #1 of 10 Old 03-11-2021, 05:13 PM Thread Starter
sam_234
Like it says,
I have a Jeep grand cherokee with 20" wheels (Summers} and I wish I could just trade them in for 18" in the winters.
Say it's so.
sam_234 is offline
post #2 of 10 Old 03-12-2021, 12:19 PM
222Doc
222Doc's Avatar
the wheel size is just the hole in the tire. In theory it could be any size under the tire size. example a 35" tire on 15" wheel is the same as a 35" tire on say 24" wheels. Its still a 35. just tire has a smaller whole or bigger hole. So yes you can run 18" wheels just keep same tire SIZE in Diameter. what ever that is for that jeep.
18 will ride better then a 20. especially on small tires like say 30" and under. 17 would even ride better yet if they fit and would cost far less then any 18" or 20" tire. Vehicles with 20s and up tend have heavier tire and wheel weight too. Wheels tend to be much heavier then the rubber per inch. Unless the 20s are say made very light Forged or other higher tech way to make them that cost BIG money.
222Doc is offline
post #3 of 10 Old 03-12-2021, 04:52 PM Thread Starter
sam_234
hey, thanks for the reply!
But then there's brakes, and yadda yadda yadda. So I can put 18"'s on my 20s?
sam_234 is offline
post #4 of 10 Old 03-12-2021, 05:10 PM
Kruzin
Kruzin's Avatar
2009 JK Wrangler
You cannot put 18" tires on 20" wheels.
You can put 18" tires AND 18" wheels on your Jeep.
'09 JK Rubicon
'01 XJ Sport
'10 Fusion
Kruzin is offline
post #5 of 10 Old 03-12-2021, 06:26 PM
mukluk
mukluk's Avatar
There is a minimum wheel size that can be run on a vehicle due to the size of the brakes, but I don't believe any year Grand Cherokee requires at least a 20" wheel. If your particular year Grand was offered with 18" wheels from the factory, you should be able to drop down to that size -- you'll still need to make sure the wheels you use have the appropriate offset or backspacing though.
2jhanna likes this.
2000 TJ SE
2005 LJ Rubicon
mukluk is offline
post #6 of 10 Old 03-30-2021, 08:51 AM
White Elemant
White Elemant's Avatar
2016 JK Wrangler
18" tires might be a tad bit small for a Jeep, like any adult size Jeep at least....
White Elemant is offline
post #7 of 10 Old 03-31-2021, 09:16 AM Thread Starter
sam_234
Holy macrel - took me three weeks to find this thread again. i'm sure I just got confused about subscrpitions.
So, the long and the short of it is, I basically don't want skinny minny 20's on the vehicle for the winter. (Ya, I'm thiinking of winter already.) I'd like some big meaty 18" tires and wheels for traction etc
Obviously I can't put 18" tires on 20' rims.
But can I squeeze 18' wheels and tires around the 18" brakes on a 2015 Grand Cherokee. With proper offests? I'm sorry if wasn't cear before.
This Answer from Mukluk appears to be the closest to reality. If I want Wrangers (i do) I suppose the easiest is to jut go into a firestone dealer and say "Can you make them fit?" - but i wanted to doube ckeck,
Thank for your your patience.
sam_234 is offline
post #8 of 10 Old 04-16-2021, 11:11 AM
gspfunk
gspfunk's Avatar
2019 WK
For future reference, this is all covered in the stickies in the WK2 section.
What engine? The Hemi and Diesel come with HD brakes and can’t run smaller than 18’s w/o 1”+ spacers. Easiest way to tell is to see if your rear desks are vented or not. Vented=HD brakes, not vented=standard brakes and 17’s should fit. If you want to stay stock diameter, use a wheel calculator to see what tire to run, but OEM on the 18’s is 265/60r18.
I’ve destroyed my OEM 18” Trailhawk wheels off road, so I just grabbed a set of JL Sahara take-offs.
19 Sting-Gray WK2 Trailhawk 08 Silver WK1 SRT8
Instagram FunkyWK2 YouTube Funky WK2
gspfunk is offline
post #9 of 10 Old 04-20-2021, 09:10 PM
BOT ROCKET
BOT ROCKET's Avatar
Originally Posted by gspfunk View Post
...can’t run smaller than 18’s w/o 1”+ spacers.
This seems like a generalization. I assume you mean they can't run a stock 18" Jeep wheel, because you could get an 18" aftrrmarket wheel with more caliper clearance or less backspacing if need be. My Fusion Sport has the same issue with having to be selective about fitting 18" wheels, but I don't think I've seen anyone say wheel spacers are the solution.
BOT ROCKET is offline
post #10 of 10 Old 04-21-2021, 11:12 AM
gspfunk
gspfunk's Avatar
2019 WK
18’s work fine. With 17’s, they have more than just a little interference with the caliper on HD brake-equipped Jeeps. The HD brakes use a different bracket than SD that pushes them out (along the face of the rotor, not toward the outside of the vehicle) to accommodate a 20mm larger rotor.
Caliper clearance is one of the big reasons you see so many people running spacers.
gspfunk is offline
