Best tire for the sand - JeepForum.com
 6Likes
  • 1 Post By bbacus
  • 1 Post By 222Doc
  • 1 Post By mukluk
  • 1 Post By Arty McGeep
  • 1 Post By 222Doc
  • 1 Post By ZblackliZard
post #1 of 9 Old 03-23-2020, 06:20 PM Thread Starter
BlueFl.Wrangler
Supporting Member
BlueFl.Wrangler's Avatar
I want to start looking into my next set of tires. All most all of my driving is on pavement, but when I do go off road, its in the sand. Looking for some suggestions on a tire that performs well in the sand
Thanks
Diplomacy is the art of telling people to go to hell in such a way that they ask for directions
Winston Churchill
BlueFl.Wrangler is offline
post #2 of 9 Old 03-23-2020, 08:03 PM
bbacus
bbacus's Avatar
There are sand tires out there but not for highway use. However whatever you buy the wider the tire the better. You should also be able to air your tires up and down....ie need an air compressor onboard.
BlueFl.Wrangler likes this.
bbacus is offline
post #3 of 9 Old 03-23-2020, 08:08 PM
222Doc
222Doc's Avatar
most any MT will be best followed by a AT and as Bacus said you need to air down. For me that is about 6psi with no side loading and 8 psi anywhere. No bead locks as well. 9 inch wheel width on a 12.5 wide tire.
222Doc is offline
post #4 of 9 Old 03-23-2020, 08:12 PM
mukluk
mukluk's Avatar
Stick with something with tighter tread and a large footprint, you want to minimise your ground pressure so that you don't sink. Somewhat aggressive shoulder lugs can be a bonus, but tread with large voids all the way across can have a tendency to dig in easily in really soft sand.
2000 TJ SE
2005 LJ Rubicon
mukluk is offline
post #5 of 9 Old 03-24-2020, 03:14 AM
Arty McGeep
Arty McGeep's Avatar
I run in the sand a lot here in the southwest. I’m running KO2’s 33x12.5x15 on the stock canyon wheels (15x8) aired down to about 12 psi. No lockers on my TJ and can come n go in the sand all day with no issues or worries.
Arty McGeep is offline
post #6 of 9 Old 03-24-2020, 11:03 AM
222Doc
222Doc's Avatar
I have ran suger sand in mOab and sandhollow on MTRks seem to work well at 6 psi. Paddles work best but you need the power to turn them.
222Doc is offline
post #7 of 9 Old 03-24-2020, 01:34 PM Thread Starter
BlueFl.Wrangler
Supporting Member
https://youtu.be/-feNvq44biE
A tad off topic---
I have a shirt exactly like the one the driver is wearing.
That is one mean sounding engine.
Do you have any idea the specifics of that engine??
Winston Churchill
post #8 of 9 Old 03-24-2020, 03:03 PM
222Doc
222Doc's Avatar
Why would I? does sound nice though. sounds like its super charged. He is filling it with racing fuel. Bet is one fun ride too. That sand hill climb is rather impressive considering he lost momentum near the top, puts on its side. Then with pure HP gooses it over the top. I would bet that jeep can cross water too.
Like this bad boy, listen to it. crossing a lake with nothing but TONS of HP.
222Doc is offline
post #9 of 9 Old 03-26-2020, 09:18 AM
ZblackliZard
ZblackliZard's Avatar
I think the TrXus STS are good sand tires, dunno if they come in smaller size though(40 inch).
Edit: just checked they have smaller size down to 29inch (they even have 33X14.50R15 those should be killers)
ZblackliZard is offline
