JeepForum.com (https://www.jeepforum.com/forum/)
-   Tires & Wheels (https://www.jeepforum.com/forum/f15/)
-   -   Best all season tires for heavy towing with Grand Cherokee (https://www.jeepforum.com/forum/f15/best-all-season-tires-heavy-towing-grand-cherokee-4383343/)
rdemopo2 01-10-2020 10:22 AM
Hey folks, I'm pretty new to the forums and did a couple searches on this topic but didn't find the answer, so hopefully I'm not posting a duplicate thread here.
I'm looking to replace the stock Michelin Premiere LTX 265/60R18 tires on my Grand Cherokee. I do pretty heavy towing (~6000 lbs travel trailer) with my Grand Cherokee, and I've read online that LT / load range E tires are helpful in reducing side-to-side roll.
I've looked around and I really like the LT versions of the Michelin Defender LTX M/S, but the smallest size they seem to make is LT265/70R18. These would fit on the rims, but I'm worried they're too big for the GC.
Does anyone here do heavy travel-trailer-type towing with their GC, and have any experience with LT / load range E tires and/or recommendations on what I should fit? I live in the northwest, so looking for an all-season tire that can handle mild winters and all four seasons on the rims.
Thanks, appreciate any advice folks have!
gspfunk 01-12-2020 10:07 PM
Lots of members running LT tires on their WK2’s. Based on your needs, I think that’s the right way to go. 32” (actually 32.1”) is the largest diameter you can run w/o rubbing in most tires, so 265/70 is larger than will fit (32.6”).
If you don’t do any off roading, an all season would work, too.
Fourtrail 01-13-2020 09:43 AM
Your wheels aren't rated for the weight nor the tire pressure to use a LT in load range E. I would look at something like the below Cooper that is load range XL (2600lbs per tire). These should be plenty for the weight you are towing and have a stiffer sidewall than your current tires and are a close look to the tread of the Michelin Defender.
https://www.tirerack.com/tires/tires...omCompare1=yes
rdemopo2 01-13-2020 04:54 PM
Thanks folks--appreciate your insights!
The time now is 04:34 PM.
Copyright ©2000 - 2020, Jelsoft Enterprises Ltd.
User Alert System provided by Advanced User Tagging (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
