Is -44 mm offset too much? - JeepForum.com
post #1 of 8 Old 01-20-2020, 12:36 PM Thread Starter
Leongorani
I am doing some wheel research and looking to buy a new wheel and tire setup from custom offsets.com there are some nice wheels that have a -44 mm offset. Now I know that a negative offset means it will push the wheels out from the body correct? If I pair this wheel with 35 inch tires, will I have rubbing issues at all? Will it rub against the stock step bar under the doors or no? Thanks!
Leongorani is offline
post #2 of 8 Old 01-20-2020, 01:13 PM
Kruzin
Kruzin's Avatar
2009 JK Wrangler
Need to know what kind of vehicle you're working with.
'09 JK Rubicon
'01 XJ Sport
'10 Fusion
Kruzin is offline
post #3 of 8 Old 01-20-2020, 05:15 PM Thread Starter
Leongorani
I have a 2019 wrangler with no lift, but I plan on lifting it atleast 3.5 inches
post #4 of 8 Old 01-28-2020, 10:33 PM
gspfunk
gspfunk's Avatar
2019 WK
Positive offset pushes them out. Negative tucks them in more. All OEM JK/JL wheels are -44 offset, so youíre keeping it stock.
19 Sting-Gray WK2 Trailhawk | Hemi | MRR | Ridge Grapplers
08 Silver WK1 SRT8
gspfunk is offline
post #5 of 8 Old 01-29-2020, 10:59 AM Thread Starter
Leongorani
Positive offset pushes them out. Negative tucks them in more. All OEM JK/JL wheels are -44 offset, so you’re keeping it stock.
Are you sure? I’m really confused now. I thought negative offset pushes the wheels out towards the road.
post #6 of 8 Old 01-29-2020, 12:26 PM
gspfunk
gspfunk's Avatar
2019 WK
Sorry! I donít know what the hell I was thinking. You are correct. OEM Wrangler wheels have a + offset of 44mm.
08 Silver WK1 SRT8
gspfunk is offline
post #7 of 8 Old 01-30-2020, 11:48 AM Thread Starter
Leongorani
Sorry! I don’t know what the hell I was thinking. You are correct. OEM Wrangler wheels have a + offset of 44mm.
Thad alright haha. Okay so if I get -44 offset then they will stick out a lot right? Do you think I will
Have running issues with a 37 inch tire on a 3 inch lift with -44 offset? I will mainly be driving on highway and light off road. I also think I will get a tire width of 12. Thoughts on a set up like this?
post #8 of 8 Old 01-31-2020, 10:02 AM
gspfunk
gspfunk's Avatar
2019 WK
I found a setup that is close, but not exactly like you described.
Another close setup.
If no one else chimes in, you might consider reposting this in the JL-specific forum.
For my taste, I feel like they’ll stick out too much, but go with what you like.
08 Silver WK1 SRT8
gspfunk is offline
