35" A/T Tires - JeepForum.com
post #1 of 9 Old 05-26-2019, 11:39 AM Thread Starter
rhbickham
rhbickham's Avatar
35" A/T Tires
What is the best 35" A/T tires that will balance out good? I have 35" BFG KM2`s that I bought from Discount Tires and they had to replace 3 of them because they wouldn`t balance out, even after roadforce balancing. Still not perfect. I have heard BFG tires are bad about balancing. Any suggestions?
rhbickham is offline
post #2 of 9 Old 05-26-2019, 01:35 PM
222Doc
222Doc's Avatar
with size i think its hit or miss or could be the person at the balancing station as well, more often then brand. you feel shimmy even if its just slight? thats tires. my 35s and lot of trail time at least once a year balanced. the 37s i have not had to re balance in 3 seasons now and more trail then street. but in that 3 season two tires were replaced for trail damage under warranty. sides wear out faster then the tops off road.
if a tire is out of round enough but well balanced. depending on the psi you run that should be in the mid20s only at enough speed would it want to hop. So even oddly shaped/ sided object can be balanced with enough weight. much like a pig can fly or a lead balloon can too. So they can balance a tire its matter of did they get it to Zero? Its not like the tire is changing its position on the wheel and they are trying to lead a target here. well they do if I air down to far i have had tires move and not lose a bead. i have lost a bead and not needed a balancing after as well.
the main complaint of BFGs i here from our club members and here on line is they cut to easy, in AZ more so. But then again all tires get cut here in AZ on harder trails for sure. hard to get through one and not have at least one jeep in 5 loose a tire. Balancing? not really an issue unless the guy cant get it right.
222Doc is offline
post #3 of 9 Old 05-26-2019, 08:02 PM Thread Starter
rhbickham
rhbickham's Avatar
You sound pretty knowledgeable on tires! Do you think places like Discount Tires get less quality tires from the manufacturer?
post #4 of 9 Old 05-28-2019, 07:59 PM
biffgnar
biffgnar's Avatar
Your heading talks about ATs but then you start talking about KM2s which are MTs? While I believe KM2s to be one of the most overrated tires in existence, they should still balance relatively easily. Sounds to me like operator error.
biffgnar is offline
post #5 of 9 Old 05-29-2019, 04:32 AM Thread Starter
rhbickham
rhbickham's Avatar
Yes KM2s are M/Ts. My next set will be A/Ts. That is why I posted.
post #6 of 9 Old 07-12-2019, 09:52 PM
Prot
Prot's Avatar
2014 JK Wrangler
My 315/70-17 Duratracs required only minimal balancing on all four sets I have purchased over the years.
Compare that with about about one pound required for BFG AT of the same size and on the same wheel.
Something happened with BFG several years ago and quality control went down significantly and their tires need a ridiculous amount of weight to balance
Cooper Discoverer ST Maxx is a tire I keep looking at as a potential alternative to the Duratracs every time I need new tires but ultimately decide to stick with the Duratracs
2014 JKU Copperhead Pearl
Too many mods to list. Too awesome to sell.
Prot is offline
post #7 of 9 Old 07-12-2019, 10:04 PM
DougRz
You're not the only one to notice this fact.
/l ,[____],
l---L -OlllllllO-
()_)-()_)-o-)_) 03 auto, Ford 8.8, 4.88, Tru-tracs
DougRz is offline
post #8 of 9 Old 08-01-2019, 03:32 PM
strykersd
If you're offroading it enough to the point you need 35s, I'd go with airsoft BBs. I was able to keep my 33s balanced but my 35s and 37s would never stay balanced once they loose a few chunks while offroading. Once I switched over to airsoft BBs I haven't had any problems.
strykersd is offline
post #9 of 9 Old 08-26-2019, 09:17 PM
DougRz
Once the bead is broken, is it a problem to reinflate?
/l ,[____],
l---L -OlllllllO-
DougRz is offline
(Five!) 35" tires w/ wheels! geis Tires & Wheels 2 03-22-2019 11:00 PM
Where to change 35" tires in south florida rla1999 Tires & Wheels 2 11-02-2018 05:53 PM
BRAND NEW 35" Off-Road Tires: Goodyear MT/R LT35X12.5R18 bobrobertsxxxxx Tires & Wheels 0 06-19-2018 08:03 PM
How do you ship 35" tires? bobrobertsxxxxx General Jeep & Off-Road Equipment 10 06-19-2018 11:08 AM
Anyone running Continental TerrainContact A/T tires? 08CanuckCRD WK Grand Cherokee & XK Commander Forum 3 01-10-2018 11:30 AM
