33x12.5x15 Duratrac Tires - 2.5in Lift - And IDC what you say! - JeepForum.com
post #1 of 9 Old 04-21-2020, 10:33 AM Thread Starter
mikeinaction
I'm done with the internet on this matter. I'm sick of hearing every answer possible. As I type, these wheels are being put on the Jeep. So for once and for all I will finally discover whether this will workout and I will give you an update with all of the details and photos. I expect minor modifications will need to be made. We'll see!! Wish me luck!!
mikeinaction is offline
post #2 of 9 Old 04-26-2020, 03:10 AM
chris87xj
RIP Chris87xj
chris87xj's Avatar
1987 XJ Cherokee
Luck!
***Chris***
chris87xj is offline
post #3 of 9 Old 05-06-2020, 01:22 PM Thread Starter
mikeinaction
Okay, 33x12.5x15 do indeed fit on a TJ with a 2.5 lift. There is absolutely no rubbing at all. I have taken them to extreme offroading spots and had no issues. The truck drives even better than it did before.
post #4 of 9 Old 05-13-2020, 05:57 AM
Tymeks
Show us a pic of everything done and sitting on the ground. Id love to see it.
Tymeks is offline
post #5 of 9 Old 05-13-2020, 05:57 AM
Tymeks
And when you say 2.5 inch lift. Did you do a combination of Body lift and suspension lift, or is it just a straight suspension lift?
Tymeks is offline
post #6 of 9 Old 05-14-2020, 07:37 AM
222Doc
222Doc's Avatar
extreme off roading? tends to be a matter of perspective. But i would venture to say that at full flex it would rub. more so if sway is disconnected. but no lockers wont be seeing hard trails anyway. I have set of Duros on the excursion in 35s about a year now they still look new. Not the quietest AT. But the excursion is a diesel anyway 7.3s are noisy.
222Doc is offline
post #7 of 9 Old 05-15-2020, 07:43 AM
jserna
1987 YJ Wrangler
JP did a story on this same set up a number of years ago. I the one thing they did or recommended is extending the bumpstops more then the kit they used had so to minimize fender contact at full stuff. One thing that you could do is just trim the lower lip of the flares to give you a little bit more clearance.
jserna is offline
post #8 of 9 Old 06-14-2020, 06:46 AM
MeyerzJeeps
Where is the best place to measure to determine the actual lift that was installed? 2004 TJ.
I was told its a 2 Mopar lift kit and its running 265...measure at 31 tires.
MeyerzJeeps is offline
post #9 of 9 Old 06-14-2020, 08:44 PM
OldFaurt
OldFaurt's Avatar
Looks good!
Bob
Ham Radio, KJ5XJ
2002 Jeep TJ, 4.0l
Just got it after retiring the 1992 XJ.
OldFaurt is offline
