2012 Grand Cherokee off-road tires recommendation - JeepForum.com
 3Likes
  • 1 Post By 222Doc
  • 1 Post By WXman
  • 1 Post By 63SUMMIT
post #1 of 11 Old 10-10-2016, 06:14 PM Thread Starter
erkfel
Hello folks,
I just bought a 2012 Grand Cherokee with all-season tires, I'm planning to go off road and planning to buy all terrain tires (maybe mud terrain), but I'm not sure what tires and especially what size is better.
The current tires are R20. I see a lot of people sell stock Wrangler tires that are also compatible with Grand Cherokee, I like this option because it's relatively cheap, but most of stock Wrangler the tires that people sell are R17-18.
I have the following questions:
- Which off-road tires do you have/recommend for Grand Cherokee (year) and it's size?
- Are R17-18 too low for off road driving on Grand Cherokee? Comparing to R20 the car clearance will be 1-1.5 inch lower with R17-18 and that seems like a big deal for off road.
Thanks!
erkfel is offline
post #2 of 11 Old 10-10-2016, 09:02 PM
222Doc
222Doc's Avatar
you are confusing the rim diameter with the tire diameter. few people that off road run 20" rims. Most common are 17" today on the newer jeeps. from there its tires and size. I would stay away from 20s to much rim and very little side wall unless you run 40" tires. Example i only run a 15" rim but the tire is 35" you can have a 20" rim and a 35" what one is taller? they are the same. But off road you air down a 20" rim on a 35" it will be riding the rim. where that 15 and a 35 can go down to 8psi and will about float over rough roads. so there are many ways to do this.
no idea what fits that jeep. If you intend to use them off road getting expensive rims is kinda like lip stick on a pig since they get so beat up in the end.
erkfel likes this.
222Doc is offline
post #3 of 11 Old 10-11-2016, 12:32 AM Thread Starter
erkfel
Got it, yes I was confused with the tire size understanding, but now I understand. Thanks for the clarification!
erkfel is offline
post #4 of 11 Old 10-11-2016, 06:46 AM
WXman
2020 J-Series Truck
Will you be in mud quite a bit? If so, you need a MT. Most AT tires will gum up in a flash and then you're stranded. On the other hand, if you'll never see mud, I would avoid MT tires because they're heavier, noisy, and will eat up your fuel economy and handling characteristics in foul on-highway weather.
There are a new breed of tires on the market that some people call "hybrid" tires that are a mix of a MT and AT. That might be a good option for you. Falken A/T3W, Goodforayear Duratrac, Nitto Ridge Grappler, etc. are some examples of these.
MOGO likes this.
Current Jeep: 2021 Gladiator Overland EcoDiesel w/ mods
Prior Jeeps/trucks/cars: Too many to list
WXman is offline
post #5 of 11 Old 10-12-2016, 10:25 AM Thread Starter
erkfel
@WXman I don't have plans to go specifically to mud, however it may be present somewhere. The options about 'hybrid' tires looks interesting to me, I take a deeper look. Thanks !
erkfel is offline
post #6 of 11 Old 10-25-2016, 03:31 PM
Tru2Chevy
Tru2Chevy's Avatar
1992 XJ Cherokee
Originally Posted by WXman View Post
Goodforayear Duratrac.
Heh....nice to see I'm not the only one who has internally renamed that famous tire company.
- Justin
1992 Cherokee Laredo - mostly stock, DD. 300k miles and counting
2004 Grand Cherokee Laredo - 4.7, bone stock - Wife's DD
Tru2Chevy is offline
post #7 of 11 Old 11-06-2016, 10:50 PM
adrake86
Duratrac.
adrake86 is offline
post #8 of 11 Old 11-23-2016, 06:21 PM
63SUMMIT
I just installed a new sets of BFG KO2 in the size 275/55R20 on my 2011 GrandCherokeeOverland. They are perfect and they look sick!
Initially, I debated on three different manufacturers: BFG KO2, CooperZeonLTZ, and Nitto GrapplerG2. They are all terrain tires, on and as well as a little off road type tires. And I do think I made the best choice!
63SUMMIT is offline
post #9 of 11 Old 11-27-2016, 08:52 AM
63SUMMIT
These are BFG KO2 275/55R20's. Pics are at Parked ride height.
MOGO likes this.
63SUMMIT is offline
post #10 of 11 Old 12-22-2016, 05:07 PM
LouC
2007 WK
Off road if you are airing down a lot as we do in sand, sticking with a 70 series aspect ratio tire is best if it fits because you have more sidewall to work with. On my 07 WK-1 Hemi I up sized from 245/65-17 to 245/70-17 which gives me more sidewall because on the beach you have to really air down (ie 12-10 lbs).
For the o.p. I would advise getting 17" rims with all terrain tires in the 245/70-17 size if you can. The larger diameter rims really limit you in off road applications.
2017 JK Unlimited Sport 6 spd
2007 WK Limited Hemi QDII
1998 ZJ Laredo 4.0 Selectrac
LouC is offline
post #11 of 11 Old 12-25-2016, 12:50 PM
63SUMMIT
^^Well it all depends on how extreme of off-roading you will be doing. Going Jeep Jamboree off-roading type course, I can see the benefit of the smaller diameter wheels/taller sidewalls tires.
63SUMMIT is offline
grand cherokee , tires
