2000 Jeep XJ Sport - 122k miles - Western NY - JeepForum.com
post #1 of 8 Old 09-18-2019, 07:50 PM Thread Starter
aglass0fmilk
1997 XJ Cherokee
Parting out a silver 2000 Jeep Cherokee XJ with 122k miles -- the body and frame are completely rusted out and will not pass inspection. It was a daily driver until the windshield cracked and inspection was due. Many good parts aside from the body and exterior accents. This vehicle has relatively low miles for Jeep XJs.
Engine runs great, no lifter tick or any knock. Relatively low miles for one of these engines. No problems with the automatic transmission or part-time 4X4 transfer case either.
I have a video from 9/15/19 of the engine running if you want to see it.
It is a 4.0L from 2000 and is slightly different from previous years. Main difference is the distributor-less ignition using coil packs. You may need to swap your distributor and old ignition system if installing this engine in an older model Cherokee.
Larger items are local pickup only... unless you arrange freight and can convince me otherwise. I am willing to ship smaller items. I am located in Buffalo, NY.
Other good parts are some interior trim pieces (dark grey/agate, correct for 1999+), factory privacy glass, running gear, cruise control parts, remote keyless entry circuit board w/ paired fob, power window motors and door locks (all working when pulled). It also has a dealer-installed power sunroof that worked when pulled.
Rear hatch is OK, small dent but no rust through. Doors, fenders, and hood are all shot.
Fuel pump worked great. Brake system worked. Power steering worked. Has the common Chrysler 8.25 rear diff with relatively low miles. Cowl vent panel is usable but needs refinishing.
Send me an email or text with what you're looking for and an offer. Some parts I will be keeping for my 97 XJ
56114006078__245CB191-2D59-49C5-ABF5-E9945089AC6E.jpg   56114191421__DBBA3724-0A68-4F22-92BF-26DA35656D6A.jpg   IMG_1351.jpg   IMG_2218.jpg
aglass0fmilk is offline
post #2 of 8 Old 10-06-2019, 04:12 AM
Camaro45th
Where are you located?
Camaro45th is offline
post #3 of 8 Old 10-13-2019, 02:17 PM
Camaro45th
post #4 of 8 Old 06-28-2020, 09:38 PM
VinceBloo
@aglass0fmilk any chance you're still parting this out, and if so would you still have the right rear fixed window piece?
VinceBloo is offline
post #5 of 8 Old 06-29-2020, 09:58 AM Thread Starter
aglass0fmilk
1997 XJ Cherokee
I have all the windows. You mean the large rectangular window in the cargo area? Not in the door, correct? The dividing strips on the door window glass (mullion bar) are rusted out so I won't sell those.
Shoot me an offer and I can pull it in the next few days. The Jeep is located in 14006.
post #6 of 8 Old 06-30-2020, 10:12 PM
VinceBloo
I was referring to the smaller fixed part of the window that's on the rear doors, but I ended up finding one locally. Thanks for the quick reply and checking though!
post #7 of 8 Old 09-04-2020, 11:41 AM
93zjer
I need the front door strikes and hardware. 95503
93zjer is offline
post #8 of 8 Old 09-15-2020, 08:04 PM
SethOfArk
Hi, I saw someone else bump this thread so I figured I would too. Do you have the stock fender flares for your part out? I'm after that specific year and color.
SethOfArk is offline
