1999 WJ. Lifted and JK axles. - JeepForum.com
post #1 of 9 Old 08-12-2019, 08:08 AM Thread Starter
walter_da_jpr
4.0 Piston Skirt Victim
walter_da_jpr's Avatar
Time has come to part ways with my WJ after 15 years and 15 years on this forum.
I will still sell whole if someone really wants it but by the end of the week id like to start shipping parts.... I'm posting here before going fully globally. You guys should have first dibs.
Details:
Its still together runs great, has a intermittent CEL for 02 sensors/or i believe down pipe cats.
99 WJ laredo auto, selectrac/242. has 275k on body but:
-Powertrain swapped in 2014 as documented on this forum. Engine was 2006 factory new, trans a Mopar rebuild and transfer case rebuilt by yours truly. Runs great has just over 90k on it. Would like to sell this as a whole power train unit (will be cheap).
-Has 2008 jk rubicon dana 44 axles w. factory lockers and 4.10s. Rear is currently in truck and bolts up with '5 point' factory style. ABS and ebrake are modified to work perfectly in WJ. Front was out for gear rebuild but will bolt on a WJ. could use better modification of spring perches to take out the / \ shape. Front axle will need ball joints and new brakes. Jeep currently has a dana 30 front w/ 3.73s in it as a driver/roller , no front driveshaft in it at the moment. I have all of the factory connectors to wire up in your jeep to get lockers.
-Jeep as 4.5" ish long arm lift. mostly rough country with some IRO and some custom. Only bolted to truck, will come right off. Lift as about 55k on it, i rebuilt the joint ends about 10k ago. Runs great and straight, no wobble or anything. 90 mph if you want.
- Has Bushwhacker flares, camel weathertech mats (front and rear), truspeed calibrator for speedo).
- Body is in good shape for almost 300k. was never wheeled hard, very shiny great paint. Stone white. Fenders modified for bushwhackers. underside of hood is starting to rust and one rocker corner is starting too. Entire underside is in good shape, what cleaned and por15d when i did engine. Spare tire well was removed and gas tank skid modified for clearance too.
Has JK rubicon wheels and some other extras. It will have 285/70/17 BFG at's that are worn out on it.
Probably forgetting something. I will sell whole this week if someone wants it but I want to compile the parts list this week and strip by end of week.
i will be reasonably with pricing either whole or parts. I will pull parts or you can come by. Pick up local to SE CT or i will ship if you pay. I just want everyone to enjoy
Thanks for all the entertainment and help over the years. Let me know if you want anything.
Pics:
Current:
Others:
WALTER
walter_da_jpr is offline
post #2 of 9 Old 09-04-2019, 12:39 AM
sparky636
Junior Member
sparky636's Avatar
Where are you located? Interested in the axles, transfer case (and associated components to go from 247tc). DM me.
Got enough posts to vote for WJ of the Month.
sparky636 is offline
post #3 of 9 Old 09-05-2019, 02:35 PM
tebeve
tebeve's Avatar
2003 WJ
Sad day for sure, but I think you're gonna make a lot of folks happy with some of those parts!
I'm in need of a decent shape rear driveshaft. Since you modded the rear axle, are you still running stock or do you by chance still have it?
Condition / price / interest?
tebeve is offline
post #4 of 9 Old 09-05-2019, 08:30 PM
tracorp1128
How much for all of it as it sits?
tracorp1128 is offline
post #5 of 9 Old 09-06-2019, 05:16 AM Thread Starter
walter_da_jpr
Located in CT
Rear driveshaft is modified
Will sell whole thing for $3900
WALTER
post #6 of 9 Old 09-08-2019, 10:03 AM Thread Starter
walter_da_jpr
No longer available whole, part out has begun.
Axles are sold.
WALTER
post #7 of 9 Old 09-23-2019, 08:14 PM
Eddiear
Do you still have the track bar?
Eddiear is offline
post #8 of 9 Old 10-07-2019, 09:33 AM
Wjmedic
How much for the bushwackers, and entire lift set up with shipping to houston tx? also is there an a-arm spacer and custom length front drive shaft as well?
Wjmedic is offline
post #9 of 9 Old 10-07-2019, 05:12 PM Thread Starter
walter_da_jpr
All parts have been sold and she was taken to the crusher this past weekend.
WALTER
