1995 ZJ parts- lots of upgrades - JeepForum.com
post #1 of 9 Old 04-15-2021, 07:12 AM Thread Starter
Normanator
Wife put my ZJ in the ditch 4 days after I installed a bunch of upgrade parts... busted up the body and a window, but damn near everything else is great.
Kolak glass eurospec headlights and wiring, DB metalworks engine mounts, heavy duty wiring harness, MSD coil/cap/rotor/plug wires, cold air intake, Kolak exhaust system (last two have 5k miles on them).
Rig has 158k miles on a 4.0l auto. Going to the scrap yard next month, so I figured I'd pass some parts on to someone for a good deal if they were looking. Probably have interior pieces if you're looking for something there too, so just ask!
Located in Polson MT, will ship anything I can for folks, or if you want the motor/trans we can arrange pick up.
Normanator is offline
post #2 of 9 Old 06-03-2021, 03:41 PM
Skye Covington
Skye Covington's Avatar
Do you still have it or am I seeing this just a little too late?
Skye Covington is offline
post #3 of 9 Old 06-04-2021, 08:44 AM Thread Starter
Normanator
Skye- I do still have this, got crazy at work and didn't get time to pull stuff, so never called the scrappers. Pm me here or text 360-951-3970 if you need something!
post #4 of 9 Old 06-24-2021, 08:16 PM
Temujin
Temujin's Avatar
Is there anything left of the luggage rack on the roof? what year is your zj. never mind about the year I'm blind lol
1995 zj 4.0 242 6l 42re trans 242 transfer case 27 spline dana 30 front 35 rear
Temujin is offline
post #5 of 9 Old 06-25-2021, 08:41 AM Thread Starter
Normanator
Roof rack was what took the most damage unfortunately, she did a slow roll over up against some rocks and its pretty beat.
post #6 of 9 Old 06-26-2021, 08:19 AM
Temujin
Temujin's Avatar
I'm looking for one of the plastic pieces that lock the rack in place. Actually the button that locks it is broken and the rattle gets to me. maybe I can fix it with some parts. Maybe one survived.I'm also looking for drivers side interior door panel what color did you have? also the switches the the door light cover and the switch from the dash board for mirror adjustment and the bottom dash panel under the ac vent drivers side. The po installed his own stereo system and was far from mechanically inclined. I did the heater core replacement and he hacked away broke things by trying to get buy without taking it apart right or try to short cut and force things. took me hours to repair a lot of the screw tabs on the plastic. Good news heat works and the rattles are gone. I suspect he tried to figure out why the temp gauge did not work. it was the wire. he cracked the cluster plastic and messed up the guage by trying to poke it with something from the side while installed and broke the needle off rofl. I found a new cluster cheap. I will probably come across other things in time if your going to keep it a while. please don't keep it on my account if it needs to go.
I'm also looking for eaton elockers for this truck stock dana 30 and 35 axles 27 spline. I not going to use this rig on trail just to get on and off construction sites. just mud and snow.
Temujin is offline
post #7 of 9 Old 06-27-2021, 06:47 PM
88ComancheLWB
1988 MJ Comanche
Looking for the backing plates & hardware for a rear disc conversion from a Dana 35. Any chance you are parting that?
88ComancheLWB is offline
post #8 of 9 Old 06-28-2021, 10:12 AM Thread Starter
Normanator
I have someone locally interested in taking the whole thing, so after I talk more with them I can get back to folks. Not really able to ship any large items (size wise) though due to being an hour and a half drive to the nearest shipping hub, so things like body and door panels are likely out.
post #9 of 9 Old 06-28-2021, 10:36 AM
Temujin
Temujin's Avatar
sounds good
Temujin is offline
