💥PRE-ORDER: RGB Oculus Bi-LED Headlights! 10% off and Ships in March! - JeepForum.com
post #1 of 4 Old 01-27-2020, 03:11 PM Thread Starter
[email protected]
Support@OracleLights.com's Avatar
PRE-ORDER NOW!
Be the FIRST to run the brand new ColorSHIFT Oculus 9" headlight from Oracle Lighting! Your 10% forum discount will apply to this purchase...get them first and at a discount until February 17th!
The popular Oculus™ Bi-LED Headlights by ORACLE Lighting are soon available in a ColorSHIFT™ RGB+W Color-Changing version! Oculus headlights feature advanced focused LED projection that outshines all the competition (including the factory LED headlights). With 3,200 Lumens of high-quality Bi-LED projection, these headlights provide enhanced driver visibility in all weather conditions. Light focus is very important for driver safety and for others who can have their vision obstructed by glare. We are proud to offer the most focused & lowest-glare LED Headlights for the JL and JT on the market. As of January 22, the ORACLE Lighting Oculus design patent had been granted by USPTO!
ColorSHIFT Oculus Headlights feature 3-Tiered RGB features in the lamps:
1) Outer Halo Ring (RGB+W)
2) Inner Halo Ring (RGB)
3) Projector Demon Eye (RGB)
Each LED feature has a separate cable output and can be connected together so all 3 create the same color or set up as 3 separate Channels or “zones” depending on the user preference and the ColorSHIFT controller selected. Please note that these features are intended for off-road “show” use only and are not compliant for street use.
The Pure-White DRL has its own wiring harness (same as the original Oculus) that connects to the fuse box with an add-a-circuit for easy and safe integration. The DRL will come on when the engine is running or can be connected to a switch (including the factory Aux switches) for additional user control.
ORACLE Part# 5839-504
MSRP: $689.95
Taking pre-orders between Jan 27th and Feb 17th for a March 2020 shipping date!
Fitment:
2018-2020 Jeep Wrangler JL
2020 Jeep Gladiator JT
Package Contents:
2x Oculus ColorSHIFT Headlights
Headlight Aiming Tool
DRL Wiring Harness
Add-A-Circuit Fuse Adapter
6x RGB Wiring Extensions
(RGB Controller not included)
Product Specifications:
Headlight Wattage: 36W
Headlight Total Lumens: 4800LM
Headlight Color Temp: 5500K
Certification: DOT SAE 5839-504 HL VOR 19
Warranty: 2 Years
Ready to order? PM us, email [email protected], or call 504-322-4094 to secure your set of these awesome lights!
ORACLE Lighting
Need an answer ASAP? - Call Us At 1-800-407-5776 M-F 8am-6pm CST
Visit our Vendor Forum
View our 2020 Catalog
post #2 of 4 Old 01-30-2020, 11:45 AM
[email protected]
Sales@OracleLights.com's Avatar
The Oracle Lighting Oculus ColorShift has the benefits and features as our original set, just with MORE!! You can wire all three ColorShifting parts together or wire them separate as a multi zone use. The NEW Oculus lights are perfect for any off road rugged Jeep that would also like the flare of the various colors!
Pre Order NOW! There will be limited quantities and we want you to be first!
Features:
Precision LED lighting projector for optimum light distribution and beam angle. Installs using original mounting hardware and headlight wiring is Plug & Play into the factory connector without additional relays or harnesses. Halo DRL features over 200 bright white LEDs for a vivid lighting impact.
Benefits:
These all-new headlamps provide enhanced driver visibility with increased and focused LED light output. Complete headlight replacement, better light focus than a simple bulb upgrade. Package includes tool for easy beam angle adjustability for proper light focus on lifted Jeeps.
VISIT OUR VENDOR FORUM HERE -
FIND YOUR JEEP MODEL:
post #3 of 4 Old 02-13-2020, 10:36 AM
[email protected]
Package Contents:
• 2x Oculus ColorSHIFT Headlights
• Headlight Aiming Tool
• DRL Wiring Harness
• Add-A-Circuit Fuse Adapter
• 3x RGB Wiring Extensions
• (RGB Controller not Included)
post #4 of 4 Old Yesterday, 09:37 AM
[email protected]
Last Day For the Oculus RGB Lights Pre order 5% Off! We will have limited quantities when they arrive so reverse your set NOW!
