NEW! High-Performance LED Fog Lights For JK/JL/JT! - JeepForum.com
post #1 of 2 Old 09-10-2019, 10:13 AM Thread Starter
[email protected]
Support@OracleLights.com's Avatar
One of the newest advancements in ORACLE Lighting's array of lighting products, these fog light replacements fit the Wrangler JK, Jeep Gladiator JT, and JL Sport & Sahara vehicle applications. This direct-fit fog light features plug-and-play wiring for easy installation. These amazing LED units push out approximately 3000 raw lumens to light up the night! (Part #5846) These make a for a perfect pairing with the new Oculus for the JL or JT!
These high performance fog lights are perfect for the off-road adventurer who wants to cover new ground on the trail! This rugged design can operate even in the worst possible conditions. Each light utilizes a rugged Polycarbonate lamp housing to withstand impact and a Solid-State luminaire design for vibration resistance. The epoxy-sealed electronics avoid moisture and corrosion.
Product Features
- Black Bezel Color
- Optional Premium ORACLE Halo Pre-installed
- Total 1,600 Lumens Light Output
- High Performance Phillips ZES™ 5W LEDs
- Horizontal and Vertical Adjustability
- Advanced Optics Design for Optimal Visibility
- Precision Beam "No Glare” Output
- Easy “Plug and Play” DIY Installation
Recent Product Improvements
- Improvements in brightness and reliability by adding a constant current LED driver to the main circuit board inside of the lamp to control the halos.
- Increased Reliability- By conditioning the power going into the LEDs this prevents degradation which can shorten the overall lifespan of the product.
- Wider Input Voltage Range- The new SMD Halos can operate on a very wide voltage range from 12V-24V so that voltage spike can not damage the LEDs.
- Brighter/ More Even Light- by moving the heat load of the resistors off the PCB we are able to increase the number of LEDs on the circuit board without thermal issues.
- LED chips upgraded from a Cree LED to a Phillips Luxeon ZES chip. They deliver a very high efficacy 130LM/W ratio while having lower thermal output.
PM us for a forum discount and shop by Jeep model on OracleLights.com!
ORACLE Lighting
Need an answer ASAP? - Call Us At 1-800-407-5776 M-F 8am-6pm CST
Visit our Vendor Forum
View our 2020 Catalog
post #2 of 2 Old 11-12-2019, 04:02 PM Thread Starter
[email protected]
NEW PRODUCT
Our new adapter brackets adjust the mounting points in order to allow for ORACLE LED fog lights (including these High Performance LED fog lights) to be added to Wranglers with the factory steel bumper option. These feature high quality steel construction with durable textured powder coat finish. The adapter brackets are a direct-fit to the vehicle without drilling or other fabrication required.
Wranglers with the factory Steel Bumper Option:
JK: 2013-2018 Jeep Wrangler Hard Rock/ Rubicon X/ 10th Anniversary Editions
JL: 2018-2020 Wrangler Rubicon w/ Steel Bumper
JT: 2020-2020 Gladiator Rubicon w/ Steel Bumper
Compatible with LED Fog Lights:
High Performance LED fog lights (#5846-ALL) [CLICK HERE]
High Powered LED fog lights (#5775-ALL) [CLICK HERE]
Dimensions: 7.3" x 1.5"
Weight: 9.6 oz
Only 1 bracket required per fog light.
Fog Lights Sold Separately
ORACLE Lighting
