How to put a 2007 JK electric swaybar in your YJ--WRITEUP WITH PICS - Page 7 - JeepForum.com
post #91 of 322 Old 01-09-2007, 10:05 PM
atomicmoose
Just call me Moose
atomicmoose's Avatar
Originally Posted by brfertig
Good question and your not an idiot. It is a lot to learn for someone who hasnt dabbled with electronics.
WHat you do is build this board. It then steps down the voltage to 5+ volts and used an IC or Integrated Circuit to control motor FUNCTION.
Then you need to have a programmable rom chip or PROM. This circuit is then connected to the PROM and gives instructions on how to operate the motor. I will purchase a PROM and program it. It allows me to use my laptop to tell the chip how long to run the motor and when to operate the lock control. Really a simple circuit compared to what is in there now. That electronic board that Paul Tyler ripped from the sway bar is some awesome engineering. I just am making a simple version of it. So the PROM is the LOGIC
Function is motor and power requirements and Logic is how to manipulate the motor to do what you want it to do.
FUNCTION + LOGIC = CONTROL
Thanks for that...
If you make this and it works, I may be interested in one.
atomicmoose is offline
post #92 of 322 Old 01-09-2007, 11:29 PM
cjb7804
Originally Posted by paultyler
Yes. Just make sure it runs the motor in the right direction. if not just switch the wires.
Edit: I checked and white is positve and red is negative.
Awsome. Thanks alot for your time, info, and push to do a mod like this. It's always cool to see stuf like this done and work effeciently without spending a ton of money.
1988 Wrangler, 2000 Cherokee Freedom Edition,
cjb7804 is offline
post #93 of 322 Old 01-09-2007, 11:47 PM
julietkilo
julietkilo's Avatar
Originally Posted by atomicmoose
Thanks for that...
In all reality simple is best, even Albert Einstein said that "if you can make something work in the simplest way, do it" or something to that effect.
Well Pauls idea with the switches are the easiest and will work. I just love electronics and I love to build them too. I want to get a parts list together and build a logical circuit so that if I want to dissconnect my axle all I have to do is push one momentary button to engage and press the same button again to dis-engage. I would also like to use a switch similar to factoy styling so it feels and looks factory.
In my setup I would have the ignition be the "on switch" or the "arm switch" and when I want to dissconnect the sway bar just press one button. Then if I want to reconnect press the same button again. Just my .02
Oh and I would include some type of indication light that the axle is dissconnected so that I dont accidentally have it disconnected on the highway.
julietkilo is offline
post #94 of 322 Old 01-10-2007, 08:40 AM
atomicmoose
Just call me Moose
If simple was best, we wouldn't do all this crap to our jeeps.
post #95 of 322 Old 01-10-2007, 10:01 AM
ebeer69
I just ordered mine.Good guy parts buddy discount $52.85.
He tells me they are priced that low in case of warranty claims. They expect to replace a few & it makes there cost on warranty repairs lower !
ebeer69 is offline
post #96 of 322 Old 01-10-2007, 10:07 AM
TerryHowe
TerryHowe's Avatar
1949 CJ3A
Dang that is cool B-)
Terry Howe
'49 Willys CJ-3A
TerryHowe is offline
post #97 of 322 Old 01-10-2007, 10:21 AM
k1llerkyle
Time to educate another person... I am confused on how the disconnect happens? Does anyone have a flex shot?
k1llerkyle is offline
post #98 of 322 Old 01-10-2007, 10:39 AM
atomicmoose
Just call me Moose
the sway bar is actually a two piece design. There are splines internal to the bar, and when engaged, they lock the two pieces together. When the lock is retracted, the two parts are free to move in different directions.
post #99 of 322 Old 01-10-2007, 10:56 AM
k1llerkyle
so when using this, are you getting full flex when unlocked?
post #100 of 322 Old 01-10-2007, 11:19 AM
atomicmoose
Just call me Moose
That is correct. We are still waiting for Paul to post some pics.
post #101 of 322 Old 01-10-2007, 02:03 PM
xjcrawlr
Guest
I ordered mine from Avondale Jeep, it will be here in 4 days
xjcrawlr is offline
post #102 of 322 Old 01-10-2007, 03:25 PM
sammon287
just ordered one in Mt. Joy PA for $67 before tax. National backorder is now -11.
sammon287 is offline
post #103 of 322 Old 01-10-2007, 04:27 PM
BudmanV6
I just placed mine on order. $64.95. I was told that they were at -20 at the distributer before they placed the order for mine. Obviously I won't be able to fiddle around with this till mine comes in off backorder, but somebody needs to see if they can figure out a way to actually use the circuit board that is on the sway bar.
1992 Wrangler Sahara, 4.0L, 5spd, RE 4.5 XD lift, Fox remote reservoir shox, 33x12.5-15 BFGoodrich All-Terrains, 15x8 black rock crawlers, JK rubicon pneumatic swaybar, JKS quick disconnect track bar, Teraflex HD SYE, Tom Woods driveshaft, Ford 8.8 w/ 4.10 gears and arb locker, D30 w/ 4.11 gears and arb locker, York 210R OBA w/ Kilby mount, Dynomax Ultra Flow SS muffler, Alterstart 165A alternator, TJ flares, and Poison Spyder rocker knockers.
BudmanV6 is offline
post #104 of 322 Old 01-10-2007, 05:24 PM
jeepsteads
jeepsteads's Avatar
i really want to see one "disconnected" im having trouble understanding it my self
jeepsteads is offline
post #105 of 322 Old 01-10-2007, 06:13 PM
Hydro
Hydro's Avatar
I understand it but I still want to see it, and I want one on my TJ!!
-Mike
Hydro is offline
You may not post new threads
