JeepForum.com (https://www.jeepforum.com/forum/)
-   Technical Articles & Write-Ups (https://www.jeepforum.com/forum/f140/)
-   -   DIY Tail Light CB Antenna Mount ($7) (https://www.jeepforum.com/forum/f140/diy-tail-light-cb-antenna-mount-7-a-1258554/)
shiftclick 08-28-2011 09:26 PM
I noticed the other day that my CB antenna mount was wiggling way too much for my liking, and after investigating it, I found that the screws going in to the sheet metal on the back of the jeep had come loose over time. Not wanting to put more holes in my jeep, I opted to make my own mount.
I had been admiring those tail-light mounts for quite some time, but the $30 price tag never agreed with my cheep sense. So I headed off to Lowes today and mulled around the sheet metal and steel aisles just looking for something to jump out at me. It needed to be easily modifiable as I have no welding/cutting tools with the exception of my Dremel and Mr. Blue Torch. While walking down of the aisles I came across this:
Large stainless steel gate hinge ($7)
http://i212.photobucket.com/albums/c...k/IMG_2958.jpg
http://i212.photobucket.com/albums/c...k/IMG_2959.jpg
I knew that with a little finessing, I might be able to make it work. The first thing I did was to fit the metal cutting wheel to my Dremel. I then through the hinge in to the vice and decided to cut the hinge side that had less metal at the bottom.
After that, I removed the tail light and did a quick, dry fit. I put the hinge behind the tail light and used a sharpie to mark where 2 other holes would need to be drilled. I then set to drilling them out.
http://i212.photobucket.com/albums/c...k/IMG_2960.jpg
Next up was another dry fit, and choosing how far I needed to bend the end to make a tab for the antenna to ride on. I had previously routed the cb antenna through the body and in to the tail light assembly and then out a hole in the side (I need to address this hole before fall sets in ). I opted to go about 2 inches from the top.
http://i212.photobucket.com/albums/c...k/IMG_2961.jpg
Here's the hole I was talking about:
http://i212.photobucket.com/albums/c...k/IMG_2965.jpg
I next put the hinge back in to the vice short side down - or the side with the tab mark on it - so I could use the bulk of the length of the hinge as a lever to help bend it. This is where Mr. Blue Torch comes in. Took about 3 minutes of heating it up - both sides - and then pushing or pulling on it to see if it was maleable yet. After that third minute BAM! It went right over. It was perfect. I carefully removed it from the vice and threw it in some water to cool it off.
http://i212.photobucket.com/albums/c...k/IMG_2962.jpg
Next it was time to install it on to the Jeep and test it to make sure the SWR was still good. Everything was good, so I put it all back together.
Finished product:
http://i212.photobucket.com/albums/c...k/IMG_2963.jpg
http://i212.photobucket.com/albums/c...k/IMG_2964.jpg
I might take it off and paint it black, but i'm pretty happy with the results! I do plan on loctiting the old mount and using it for my signal flag when we head out to the offroad park.
http://i212.photobucket.com/albums/c...k/IMG_2966.jpg
Hope that helps you guys!
The time now is 11:49 AM.
Copyright ©2000 - 2020, Jelsoft Enterprises Ltd.
User Alert System provided by Advanced User Tagging (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
