Tree Soft Shackle - 38,000 lb. Breaking Strength - JeepForum.com
post #1 of 1 Old 02-20-2019, 02:38 PM Thread Starter
TRE_Kristen
2015 JK Wrangler
Talking Tree Soft Shackle - 38,000 lb. Breaking Strength
Description
Our Tree Soft Shackle is a direct replacement for Standard Tree Straps. The Tree Soft Shackle is made from Heavy Duty Dyneema SK75 synthetic rope and has a breaking strength of 38,000 lbs. This Tree Soft Shackle requires less connection points when using a tree as an anchor point while winching. The Tree Soft Shackle is 8 ft in length and can be wrapped around a tree so that our Safety Thimble II or a winch hook can be connected directly onto the tree shackle therefore eliminating the need to use any other connection equipment such as standard soft shackles or D-rings as would normally be required using standard tree straps. The Tree Soft Shackle can be used on trees, poles, rocks or any other object that you are using as an anchor point. Our Tree Soft Shackle can also be used the same way as any of our other Soft Shackles.
Tree Soft Shackle Benefits:
  • Reduces the amount of equipment needed compared to a standard tree soft shackle
  • Diameter of 7/8″ reducing the chance of damaging trees
  • Can be used on trees, rock, poles or anything else that doesn’t have sharp edges
  • 8 ft. in length
  • Has a 4 ft. heavy Duty Nylon sheath to help prevent abrasion
Note: We recommend using the Tree Soft Shackle on objects less than than 24 inches in diameter
Some of the Advantages of Soft Shackles:
  • Lightweight – They are so light they even float
  • Strong – Made with heavy-duty SK75 Synthetic Rope fibers. Stronger than steel cable in the same size.
  • Can be wrapped around almost anything without causing damage to the vehicle or scratching paint.
  • Our soft shackle design includes an easy to pull string that make it easy to loosen the soft shackle after use.
  • Easy to store – place them under your seat, in your pocket or wrapped around your roll cage
https://tacticalrecoveryequipment.co...-soft-shackle/
TRE_Kristen is offline
soft shackle , synthetic rope , tree shackle
Soft shackles Vinman General Jeep & Off-Road Equipment 76 11-11-2018 09:49 AM
Winch Rope Extensions - 21,000 lb Breaking Strength TRE_Kristen Vendor Display 0 05-24-2018 04:27 PM
3/8″ Synthetic Replacement Winch Rope – 18,500 lb. Breaking Strength TRE_Kristen Vendor Display 0 05-11-2018 04:56 PM
Video Tutorial Soft Rope Shackle DirtyBastard82 General Jeep & Off-Road Equipment 16 01-02-2018 04:02 PM
You may not post new threads
You may not post replies
