RIGID Light Mount Brackets For 07-18 Jeep Wrangler JK - JeepForum.com
post #1 of 2 Old 11-18-2018, 08:35 PM Thread Starter
Spiderxx
This is a pair of USED RIGID Industries windshield light brackets for either LED or Halogen lights. They will fit a '07 to '18 Jeep Wrangler JK model only. These WILL NOT fit the new 2018 JL model.
All of RIGIDís grilles, OE Brackets, and Mounts are made with 100% stainless steel and covered with UV and abrasion resistant powder-coat to ensure years of use in the harshest conditions.
RIGID Industries offers a lifetime warranty on these brackets.
They are in very good condition. The powder coat is intact over most of the bracket and they hardly have any marks other than where the bolts and light bracket itself set on the bracket. The bottom hole of where the light mounts does have powder coat chipped off from the use of a lock washer. It spun and marked the powder coating. The powder coat is chipped off in a circle on the bottom side of where the lights bolted to the bracket. I used a lock washer on it which made the mark. You can see this in photo #2. Also both brackets have one mounting hole that is slightly bent from over tightening the bolt to mount the brackets to the windshield. The bolt head made an impression to the hole. Still very usable and not noticeable once mounted to the jeep. I rather point all this out than have any surprises if you buy.
Spiderxx is offline
post #2 of 2 Old 02-28-2019, 09:26 PM Thread Starter
Spiderxx
Still Available.
Spiderxx is offline
You may not post new threads
