Jeep TJ tow harness kit cooltechllc.com - JeepForum.com
post #1 of 3 Old 12-04-2016, 01:37 PM Thread Starter
TurdyFive
From cooltechllc.com, a wiring harness for flat towing your TJ that does NOT tie into the Jeep's factory wiring. Was installed and only used once. Also including a Roadmaster 4 pin umbilical.
From their website:
This is a complete tow harness kit for your 1996-2006 Jeep Wrangler TJ- all trim levels. This kit should be used if you intend to flat-tow your Jeep behind your SUV or motor home. This is a complete package that includes everything you need to have STOP, RUNNING LIGHT, and TURN SIGNAL operation within your rear tail lights. A key feature of this kit is that it is a completely separate harness and it DOES NOT tap into your OEM wiring. This is a BIG ADVANTAGE compared to other kits, as the OEM wiring is never compromised and there are no diodes or other devices to add because the system is independent of the OEM wiring. This kit is VERY easy to install and uses OEM-like Weatherpack connectors. You simply add the additional socket and bulb into each tail light housing, and then plug the supplied harnesses together. Everything has been pre-made for you. Of course, complete, color-illustrated instructions are included!
The harness uses heavy-duty 14-gauge fully insulated cables. One cable runs from you driver's side rear tail light to the front of the Jeep and the other cable inter-connects the driver's side cable to the right rear tail light. Simple.
This newly updated complete kit includes a Heavy Duty cast (not stamped) 4-pin connector that can be mounted at the front of your Jeep. The 4-pin connector can be mounted into the bumper or installed using the (included) bracket.
Package Includes:
17' Heavy Duty, 14 gauge 4-wire Cable (not inferior un-shielded flat cable)
7' Heavy Duty, 14-gauge 4-wire cable to inter-connect left and right lights
Left and Right Light Sockets and 2-way bulbs
Heavy Duty 4-pin Cast Round Female connector
Connector mounting bracket
http://www.cooltechllc.com/wrangler-...rness-kit.html
Asking $80 shipped.
Thanks!
"Too weird to live. Too rare to die."
TurdyFive is offline
post #2 of 3 Old 04-30-2017, 07:31 PM
Tjmaverick
Jeep tow light kit
Is this still for sale? If so, please contact me at [email protected] yahoo.com
Tjmaverick is offline
post #3 of 3 Old 10-16-2018, 09:19 PM Thread Starter
TurdyFive
Still available.
You may not post new threads
