[AL] Closing up my shop clear out. - JeepForum.com
post #1 of 6 Old 01-19-2020, 05:11 PM Thread Starter
LimeLJ
LimeLJ's Avatar
I moved on from my shop so I am clearing out a bunch of stuff. I can take PayPal as payment. If you are near Huntsville, AL you can schedule a time with me to come by my shop and see what I have to get rid of. There is a bunch more not listed here. Everything shown here is 35 minutes away from my current place so I will ship out items one or twice a week.
2x heater cores, brand new, for 1997-2001 XJ, $35 shipped each.
1997 XJ PCM 280AC - $30 shipped
XJ PCM, Verify that yours is 493AE or similar, $30 shipped
One the few Sprintex prototype supercharger kits for the XJ, no mileage, ran for about fifty minutes on the dyno before deciding it was not enough for my needs.(Stock 4.0L engines only for this! Don't put this on your stroker.) $1,200 plus shipping, shipping will not be cheap($100+) as it is bulky, heavy, and I intend to package the hell out of it. As this was a prototype kit you should expect to need to do your own tuning, EFI control, and more. This will be the last time I post this before it gets put in a box in the attic and forgotten about forever.
4x Spidertrax WHS002 wheel spacers, 5x4.5 1.25" thick, ~50,000 miles, $120 shipped
Corbeau MJ seat adapter brackets, $150 shipped
Chrome grill pieces for XJ, aftermarket, $50 plus shipping.
XJ instrument clusters - Varying condition on needle fade and lens appearance. Please specify the year you need! I have one for 1997 to 1998.5 years and the rest are 1998.5 to 2001.
XJ full instrument cluster - $70 shipped, $100 shipped with mileage and VIN programmed.
See something you like? Ask and I will get more pictures along with a price.
34, 35, 37, and 41 tooth speedometer gears "short" for newer NP231/NP242 transfer cases, some are new, will check when asked - $25 shipped for new, $10 shipped for used.
XJ right rear replacement floor pan, $50, shipping will be expensive.
MOPAR ignition coil pack for distributorless 4.0L engines, new, $150 shipped.
1997 XJ wiper stock, used with 200,000+ miles, works, $15 shipped.
Rough Country Transfer Case Drop Kit for TJ(Probably with metric bolts) and an assortment of stickers I stashed in there, $20 shipped.
Fixed sway bar end links for a JK, I think, longer from a lift kit. A friend left them at the shop. $15 shipped.
Various, ask and I will get more pictures.
MOPAR cruise control retrofit kit for 2002? to 2004 TJ - These are hard to find. You will need the switches($100 for a pair from Standard Motor Products) and the wiring that goes into the cab to the steering wheel clock spring will need to be replaced.(Some wire and a few spade connectors.) This kit requires disassembling one of the PCM connectors to add the terminals.(You can see when I installed it here: https://www.jeepforum.com/forum/f22/...ml#post7877414) - $100 shipped
2004 Jeep Wrangler Unlimited - L99/LS3 6L80E Swap
1997 Jeep Comanche - 4.7L Stroker, Lifted, "Restored"
LimeLJ is offline
post #2 of 6 Old 01-21-2020, 08:23 AM
badgerwithhands
2007 WK
Doubtful, but do you have any WK or XK stuff?
07 WK Overland CRD, cargo LEDs, OME HD, MOPAR skids, rack,
future mods: tires, lights, CB, skids,
badgerwithhands is offline
post #3 of 6 Old 01-21-2020, 06:07 PM Thread Starter
LimeLJ
LimeLJ's Avatar
Nope, only XJ, MJ, and LJ.
LimeLJ is offline
post #4 of 6 Old 01-22-2020, 07:17 AM
snobrder540
snobrder540's Avatar
What do you have for the LJs?
snobrder540 is offline
post #5 of 6 Old 01-22-2020, 09:09 PM Thread Starter
LimeLJ
LimeLJ's Avatar
Primarily the cruise control kit listed above. I also have a 0 mile rebuilt factory rear driveshaft for the 4.0L/42RLE drive train and an used Borla 140103 exhaust. The muffler has some rust starting on the top of it, but I assume Borla would cover that under their warranty program.(The exhaust would also be expensive to ship.) I also have the PCM, TCM, and companion SKIM from my LJ.
LimeLJ is offline
post #6 of 6 Old 01-23-2020, 10:30 AM
snobrder540
Ok, Thanks for letting me know @LimeLJ
You may not post new threads
