ZJ Will Not Reverse - JeepForum.com
post #1 of 6 Old 08-05-2019, 07:26 PM Thread Starter
camerond1
ZJ Will Not Reverse
Hey guys, I'm new here!
I'm looking at a Grand Cherokee 1996 ZJ and the owner says all forward gears work fine, but the reverse gear acts as if it is neutral.
No crash history, has over 200k miles, Limited model with the V8, and its an automatic.
No lift, no tire size change.
I'm wondering if this is a common or known problem and yes I know its vague but its hard for me to investigate the problem as I don't own the vehicle yet.
Thanks!
camerond1 is offline
post #2 of 6 Old 08-06-2019, 07:43 AM
LordHobbit
LordHobbit's Avatar
might just be a misadjusted transmission gear selector linkage? so when you think it is reverse it's actually in neutral? Go play around and see. Certainly he'll let you take it out for drive.
93 red ZJ 196k 4.0. Spent more money than I should have ...
LordHobbit is offline
post #3 of 6 Old 08-06-2019, 07:51 AM
V8GCZJ
The band clamp probably fell out.
V8GCZJ is offline
post #4 of 6 Old 08-06-2019, 01:04 PM
jrcromwell
jrcromwell's Avatar
Here are an operational chart and a No reverse possible causes list.
jrcromwell is offline
post #5 of 6 Old 08-06-2019, 02:45 PM Thread Starter
camerond1
Sorry, which band clamp are you talking about?
post #6 of 6 Old 08-06-2019, 03:05 PM
Timo_90xj
Timo_90xj's Avatar
Rear band and it's linkage system - that is what mechanically engages reverse. You need to drop the fluid pan to be able to see & adjust rear band.
***Under construction***
Timo_90xj is offline
gear , jeep , reverse , transmission , zj
