JeepForum.com (https://www.jeepforum.com/forum/)
-   ZJ Grand Cherokee Forum (https://www.jeepforum.com/forum/f13/)
-   -   ZJ Will Not Reverse (https://www.jeepforum.com/forum/f13/zj-will-not-reverse-4366253/)
camerond1 08-05-2019 07:26 PM
ZJ Will Not Reverse
Hey guys, I'm new here!
I'm looking at a Grand Cherokee 1996 ZJ and the owner says all forward gears work fine, but the reverse gear acts as if it is neutral.
No crash history, has over 200k miles, Limited model with the V8, and its an automatic.
No lift, no tire size change.
I'm wondering if this is a common or known problem and yes I know its vague but its hard for me to investigate the problem as I don't own the vehicle yet.
Thanks!
LordHobbit 08-06-2019 07:43 AM
might just be a misadjusted transmission gear selector linkage? so when you think it is reverse it's actually in neutral? Go play around and see. Certainly he'll let you take it out for drive.
V8GCZJ 08-06-2019 07:51 AM
The band clamp probably fell out.
jrcromwell 08-06-2019 01:04 PM
2 Attachment(s)
Here are an operational chart and a No reverse possible causes list.
camerond1 08-06-2019 02:45 PM
Sorry, which band clamp are you talking about?
Timo_90xj 08-06-2019 03:05 PM
Rear band and it's linkage system - that is what mechanically engages reverse. You need to drop the fluid pan to be able to see & adjust rear band.
The time now is 06:58 PM.
Copyright ©2000 - 2020, Jelsoft Enterprises Ltd.
User Alert System provided by Advanced User Tagging (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
