ZJ Limited wont try to crank - JeepForum.com
post #1 of 1 Old 01-07-2017, 04:21 PM Thread Starter
BigTrev206
1993 XJ Cherokee
I've been helping a friend with her 1995 ZJ Limited with the 5.2 in it for a few days and we cant get it to crank, took the starter out and had it tested, the starter and solenoid tested fine. So we moved on and tested her ignition switch and it had a bad pin in the crank position so we replaced that but still nothing changed. Tested the Relays for the starter circuit and they registered as fine according to a friend of ours. Now we're thinking its a bad neutral safety switch or a worn wire shorting somewhere. If it helps about the same time this happened the fan blower got stuck to always be on when there's power to the battery and the radio started cutting on and off. So I guess I'm looking for 2 things
1 the starter circuit wiring diagram.
2 some help figuring this out because we've been ripping our hair out in the snow trying to figure this out.
BigTrev206 is offline
neutral safety switch , no crank , starter relay , wiring diagram , zj
