ZJ dies randomly and refuses to restart unless I spray intake w/ether - JeepForum.com
post #1 of 23 Old 05-27-2020, 02:44 AM Thread Starter
Bdrew
Bdrew's Avatar
So I'll randomly be driving and all the sudden Jeep just dies then will refuse to re start unless I spray intake with starting fluid... I have. 1995 grand Cherokee zj 4.0 v6... Any ideas as to what might be the cause of this???
Any help/suggestions would be greatly appreciated
-B
Bdrew is offline
post #2 of 23 Old 05-27-2020, 04:40 AM
V8GCZJ
V8GCZJ is offline
post #3 of 23 Old 05-27-2020, 05:02 AM
jtec
jtec's Avatar
2014 JK Wrangler
this is likely an I6 not a V engine.
My first thought as it will fire up with spray is to check fuel pressure.
Next might want to look at plugs.
jtec is offline
post #4 of 23 Old 05-27-2020, 05:12 AM
MikeMiller98GC
My 98 Grand Cherokee use to do the same thing and I found the problem was in the ECM. Company in Florida wanted $600 to repair it but since I have a degree in electronics and all the tools needed. WHY NOT! The Jeep hasn't stalled in over a year. The hardest part of the job is getting the board out of the potting material. I would recommend looking at ever solder joint through a microscope (if possible). Some of the joints I though looked good didn't look so good under a microscope. I used a de-soldering iron to remove all the old solder to lay down fresh solder. Hope this helps, I fought this problem for a year before the fix! Youtube 98 Grand Cherokee ECM repairs
MikeMiller98GC is offline
post #5 of 23 Old 05-27-2020, 05:45 AM
jtec
jtec's Avatar
2014 JK Wrangler
Right now I think PCM is a leap in troubleshooting. I cant see the cause and effect of spraying starting fluid on solder loints.
jtec is offline
post #6 of 23 Old 05-27-2020, 02:44 PM
MikeMiller98GC
The fuel pump is control through the computer and with the bad solder joints the fuel pump would just quit pumping. I had to jump start mine after every stall, that is when a guy mentioned the zip tie solution for the computer. Zip ties worked but after researching the problem further I decided to do the permanent fix.
post #7 of 23 Old 05-29-2020, 11:00 AM Thread Starter
Bdrew
Bdrew's Avatar
Why would I spray starting fluid on the solder ??? I'm spraying it in the intake
Bdrew is offline
post #8 of 23 Old 05-29-2020, 11:01 AM Thread Starter
Bdrew
Bdrew's Avatar
So now it's just completely dead and refuses to start at all... Took off a spark plug and apparently it's not getting any spark
Bdrew is offline
post #9 of 23 Old 05-29-2020, 11:02 AM Thread Starter
Bdrew
Bdrew's Avatar
It's now STUCK up at Starbucks so I could really use some help... What's the most likely cause of no spark??
Bdrew is offline
post #10 of 23 Old 05-29-2020, 11:33 AM
jtec
jtec's Avatar
2014 JK Wrangler
sorry my bad grammar - why would spraying starting fluid into intake have any affect on solder in PCM?
You need to check
fuel pressure. with a gauge.
Is there 12v at injectors?
is there 12v at coil?
MikeMiller98GC correct the issue is known BUT I thought to work thru the BASICS before delving into PCM.
jtec is offline
post #11 of 23 Old 05-29-2020, 12:49 PM
jeepjeepster
Does the check engine light come on when you first turn the ignition on?
1994 ZJ-I6 w/270,000 mi
1998 ZJ 5.9 w/66,000 mi Slate Black
2004 KJ w/108,000 mi
jeepjeepster is offline
post #12 of 23 Old 05-29-2020, 02:38 PM
At1bob
At1bob's Avatar
Lazy PCM
I also believe this is a leap in troubleshooting. But if you go this route search for lazy PCM and there is a good thread on rebuilding it and replacing the bad capacitors.
At1bob is offline
post #13 of 23 Old 05-29-2020, 02:44 PM
At1bob
At1bob's Avatar
Need the codes
I got stuck once like that and it was the camshaft position sensor located in the distributor. It was easy to change . The crankshaft position sensor is not easy, do not confuse them since they have the same acronym. So you need the codes to determine which it might be. Also I did not try to spray any starter fluid at the time to see if that made a difference.
At1bob is offline
post #14 of 23 Old 05-29-2020, 08:27 PM Thread Starter
Bdrew
Bdrew's Avatar
The only 2 codes I get is 32 and 55
Bdrew is offline
post #15 of 23 Old 05-29-2020, 08:33 PM
jeepjeepster
You sure on that 32? The V6 doesnt have an EGR valve... Nor does the I6....
