ZJ A/C System Re-install - JeepForum.com
post #1 of 7 Old 08-13-2019, 02:25 PM Thread Starter
JGC403
JGC403's Avatar
I had completely removed all of the under hood components to the A/C system on my 1995 ZJ several years back and of course didn't save any of it. Figured that if I ever wanted to put it back on I should be able to get all new parts anyways. Well now I am putting the A/C system back on and found a few parts I couldn't buy new. I think I'm down to only missing one piece though, I can buy a new sensor that screws into the accumulator/ dryer, but the one I am having trouble finding is the sensor that is in one of the lines near the compressor right in front of the intake manifold. I'm not sure if its the high or low sensor, the Chilton manual is usless for the A/C system.
JGC403 is offline
post #2 of 7 Old 08-13-2019, 02:55 PM
wingless
wingless's Avatar
1994 ZJ
Welcome to the forum.
Why not get that missing part from a junk yard?
The evaporator is a common failure point. Why not suffer like the rest of us and replace that part to attain a working system?
wingless is offline
post #3 of 7 Old 08-13-2019, 02:57 PM
jeeepguy
jeeepguy's Avatar
Maybe contact JeepAir and see if they can help?
"Si Vis Pacem Para Bellum"
"Great danger lies in the notion that we can reason with evil"
Doug Patton
...We use words like honor, code, loyalty. We use these words as the backbone of a life spent defending something. ...I have neither the time nor the inclination to explain myself to a man who rises and sleeps under the blanket of the very freedom that I provide, then questions the manner in which I provide it. I would rather you just said thank you, and went on your way, Otherwise, I suggest you pick up a weapon, and stand a post...
I bought the HI-WAY BLASTER HORN that's 139dB and every time I honk the horn an Angel dies.
Revelation 13:16-18
16 - He causes all, both small and great, rich and poor, free and slave, to receive a mark on their right hand or on their foreheads,
17 - and that no one may buy or sell except one who has the mark or the name of the beast, or the number of his name.
18 - Here is wisdom. Let him who has understanding calculate the number of the beast, for it is the number of a man: (Real ID and RFID chips)
Think about it...
jeeepguy is offline
post #4 of 7 Old 08-13-2019, 03:05 PM Thread Starter
JGC403
JGC403's Avatar
Thanks for the welcome.
That is what I'll have to do if I can't find it new. Wanted to replace it with new if I could so that everything is new and should last a while.
I hope the evaporator is still good in mine. I'm putting it all back together now so I should have a working system. How difficult is that to get to?
JGC403 is offline
post #5 of 7 Old 08-13-2019, 03:44 PM
wingless
wingless's Avatar
1994 ZJ
Replacing the evaporator is the most difficult job to perform on the Jeep.
It would surprise the heck out of me if yours is still good.
Connect a vacuum pump to one end of the evaporator and plug the other to see if it leaks.
Don't waste your time w/ the system and a bad evaporator.
This topic shows my evaporator replacement. That topic is also applicable to your vehicle.
wingless is offline
post #6 of 7 Old 08-13-2019, 04:39 PM
zjosh93
It's the high pressure cut-out switch. Available on RockAuto under:
Jeep:95:Grand Cherokee:5.2:Electrical-Switch & Relay:Refrigerant Pressure Switch
Several options from $8.71 to $23.79. Looks like you need to know if you have the round or oval connector.
Edit: the evaporator in my 93 is still original and doing fine.
zjosh93 is offline
post #7 of 7 Old 08-13-2019, 08:17 PM Thread Starter
JGC403
JGC403's Avatar
Thanks didn't see that one down that far. I only saw the ones under the A/C clutch switch.
Best 1/4 mile time to date, 13.396 sec @ 101.74 mph
JGC403 is offline
