ZJ adjustable front lower control arms install help - Page 2 - JeepForum.com
post #16 of 27 Old 02-17-2017, 11:20 AM
Ace14
Originally Posted by kg6mov View Post
If eliminating cam bolts, must set caster by adjusting arms.
Simple move for you is to keep the cam bolts and set the arms to stock length, then care about the rest when you get adjustable uppers.
This 100 percent. Basically you are using the arms just for clearance not to adjust anything (yet). So keep it all as it was just with the new arm.
2003 Inca Gold Rubicon-Metal Cloak Armor, Currie Suspension, 35s.
1998 5.9 ZJ -DD/ work in progress
Ace14 is offline
post #17 of 27 Old 02-20-2017, 08:20 PM Thread Starter
CamoX413
Got it.
So I started removing my front driver side lower and I got the nut of on the body side, then I started tapping the bolt out with a rubber mallet. The bolt only came halfway out. Now It's like the control arm shifted enough already that the bolt is Cockeyed and I'm having trouble getting it the rest of the way out. I've been rocking the jeep forward and backward and nothing. Is there a trick to this?
CamoX413 is offline
post #18 of 27 Old 02-21-2017, 01:40 AM
TheGrimReaper
Originally Posted by CamoX413 View Post
Got it.
Haha yea, a rubber mallet brother. In all seriousness, I just ran my second jack underneath to clear the right angle to loosen the arms.
TheGrimReaper is offline
post #19 of 27 Old 02-21-2017, 09:35 AM Thread Starter
CamoX413
I'm not following you man. Did you use the jack to relieve pressure on the control arm?
I'm also concerned that I'm going to have trouble getting the bolts back in with the new control arms since I can't get the bolt holes to line up properly.
CamoX413 is offline
post #20 of 27 Old 02-21-2017, 10:39 AM
TheGrimReaper
Yep, the jack relieves the pressure making it easy to get that bolt out.
post #21 of 27 Old 02-21-2017, 11:50 AM Thread Starter
CamoX413
Where did you jack it up from? I tried last night to jack it up on that side of the axle and it didn't seem like it shifted the control arm at all
CamoX413 is offline
post #22 of 27 Old 02-21-2017, 07:52 PM Thread Starter
CamoX413
Never mind. I put jack stands under the body then used the jack to manipulate the axle. Came out super easy.
CamoX413 is offline
post #23 of 27 Old 02-22-2017, 09:31 AM
TheGrimReaper
Yep that's exactly the way to do it!
post #24 of 27 Old 02-22-2017, 09:45 AM Thread Starter
CamoX413
I had heard that you could do it with the wheels on the ground and rocking the jeep foreward and backward which is what I was trying to do but that didn't work at all.
CamoX413 is offline
post #25 of 27 Old 02-22-2017, 09:08 PM
TheGrimReaper
Yea, I was changing my tires so they were already in the Jack stands...when I messed with my control arms...it was super easy once I got the Jack underneath to make the angle and pressure less intense and then it was cake...a delicious cheesecake.
post #26 of 27 Old 02-25-2017, 05:18 AM
coralman
USER OF PARTS CATALOGS
coralman's Avatar
I like cheesecake so much I started making my own...blueberry or pumpkin. When I'm not working on jeeps of course, haven't found a cussing flavored cheesecake yet.
Originally Posted by HighLonesome
coralman is offline
post #27 of 27 Old 02-25-2017, 10:59 AM
TheGrimReaper
Haha I'm telling you, I might have to get one, cya today is a jeep fixin day
