Zj 5.9 Operating Temperature Range - JeepForum.com
 2Likes
  • 1 Post By Timo_90xj
  • 1 Post By StPaul59
post #1 of 11 Old 07-07-2020, 12:45 AM Thread Starter
omerozturk
omerozturk's Avatar
Dear All,
I am a 5.9 owner from Turkey. In two weeks, I will start to a journey to South part of the Turkey. In order to understand general structure of the cooling system, I would like to learn about your comments and defined optimal working temperature for the vehicle.
Regards
omerozturk is offline
post #2 of 11 Old 07-07-2020, 01:41 AM
Zilliver
Do you have any problems with the temp?
If the needle is in the middle part, you are all good.
98 Grand Cherokee 5.9 - daily
95 Grand Cherokee 5.2 - offroad
Zilliver is offline
post #3 of 11 Old 07-07-2020, 02:54 AM
Timo_90xj
Timo_90xj's Avatar
95C-105C is normal, in extreme cold it might drop slightly lower and creeps higher in heavy use. I do not feel comfortamble seeing engine temps above ~105C (220F) for extended period of time.
***Under construction***
Timo_90xj is offline
post #4 of 11 Old 07-07-2020, 04:44 AM
V8GCZJ
That's why i run a 180 t stat. 195 is stock.
V8GCZJ is offline
post #5 of 11 Old 07-07-2020, 05:36 AM Thread Starter
omerozturk
omerozturk's Avatar
Till now, I did not feel any problem at all. During hot summer days with AC on, while climbing ramps, needle slightly passes 100deg C but not touches to 105 deg C Line.
Before my trip, I just wanted to be sure about my cooling system.
post #6 of 11 Old 07-07-2020, 05:55 AM
Timo_90xj
Timo_90xj's Avatar
That sounds absolutely normal. However, I suggest installing an external auxiliary transmission cooler, and if you rarely see well- below freezing temps in your area bypass the radiator loop in the transmission cooler circuit.
When I swapped my original radiator to an all-aluminum 2-row unit and installed an external auxiliary transmission cooler, I saw a drop in average engine temp from 102-103C to a rock-steady 95C under most circumstances.
post #7 of 11 Old 07-07-2020, 06:00 AM Thread Starter
omerozturk
omerozturk's Avatar
Thanks for the comments and the suggestion. I will make a quick search for the external auxiliary transmission cooler. Do you have any brand that fits perfectly?
98 Grand Cherokee 5.9 Limited LX - daily
post #8 of 11 Old 07-07-2020, 07:34 AM
PolkaPower
PolkaPower's Avatar
The biggest one you can make fit is your best choice.
Sent from my BND-L24 using Tapatalk
PolkaPower is offline
post #9 of 11 Old 07-07-2020, 09:24 AM
Timo_90xj
Timo_90xj's Avatar
I bought a Derale 9000- series 9-row plate & fin cooler. It is enough for my climate here in Finland (temps between May-Septmeber very rarely exceed 30C, most of the summer it is between 15-25C). Buy larger for warmer climate.
Tomcorr likes this.
post #10 of 11 Old 07-07-2020, 12:11 PM
StPaul59
Right...
1996maroonzjf likes this.
StPaul59 is offline
post #11 of 11 Old 07-07-2020, 11:47 PM Thread Starter
omerozturk
omerozturk's Avatar
I see, In here situation is harder Generally 30 - 35 deg C. Additionally, each year I visit south or west part of the county which is hotter than my city. I will search for bigger one
