Zeppa front driveshaft on a NP242 - JeepForum.com
post #1 of 2 Old 06-16-2019, 07:27 PM Thread Starter
kb9mfd
I have a 1996 Limited that had a NP249 that failed. I put in a NP242 instead and had to redo the rear driveshaft (ISY vs OSY). The front though has a zeppa, and it seemed a little tight when I reinstalled it. According to the sticky on this ( https://www.jeepforum.com/forum/f13/...1-np242-685644 ) it said the NP249 and the NP242, other than different tails, had the same dimensions. I am guessing not, at ride height the FSM says the boot should be at 5.61", mine is at 5.0" so the NP242 must be 1/2" shorter. Does anyone know if I am running the risk of bottoming out that zeppa? It is at factory height and I have no plans for lifting it. I cannot seem to find what the min / max is for the zeppa travel. It does have the adjustable propeller shaft, but I am told that is not actually adjustable after installation. Thanks!
kb9mfd is offline
post #2 of 2 Old 06-16-2019, 11:24 PM
Timo_90xj
Timo_90xj's Avatar
249 and 242 have the exact same front case halves and same front output yoke. So they measure exsctly the same as far as front DS length is concerned.
***Under construction***
Timo_90xj is offline
