Wont Shift after Highway? - JeepForum.com
post #1 of 9 Old 01-21-2015, 03:39 PM Thread Starter
Gibby913
My jeep is having a hard time shifting after going over 65 on the highway. As long as I don't go on the highway she shift fine. But the moment I get on the highway and then get off to slower speeds, she'll downshift but then go to 3000rpm without shifting. What causes this? No metal in the pan, recently upgraded all electronics from cascade, except for the speed sensor on the outside of tranny. Any ideas?
Also, after I replaced all electronics inside case she seemed to shift fine even after coming off of highway....She just started doing it again this past week.
-=Gibby=-
1997 Jeep Grand Cherokee 4.0L I-6 150,600
Gibby913 is offline
post #2 of 9 Old 01-21-2015, 03:48 PM
Pierre_r
Pierre_r's Avatar
1989 XJ Cherokee
I hade something like that happen to mine and it was the lock up solenoid that had failed.
It stored a code for that fault so yours should also have a saved code.
I checked the codes on my 93 with the keytrick.
Yours are easier since you have an obd outlet, just hook up a scanner/reader and see what it says.
Jeep Cherokee XJ 4.0 -89
Jeep Cherokee XJ 4.0 -90 (partsjeep)
Jeep Grand Cherokee 5.2 -93
Chevrolet Silverado 2500 6.5TD -94
Chevrolet C20 6.2 -82
Pierre_r is offline
post #3 of 9 Old 01-21-2015, 05:25 PM
ZeeJay1997
when you go over 65 then stop, you have first gear only. when you turn the engine off and restart, it shifts fine until you go over 65, then the problem starts over. is this an accurate interpretation?
ZeeJay1997 is offline
post #4 of 9 Old 01-23-2015, 11:57 AM Thread Starter
Gibby913
@Zee Jay
Yep pretty much. But I usually dont have to turn the engine off. I just pop her in neutral and that usually does the trick. Usually. But if not then yes shutting her off always fixes the issue.
@Pierre
Wouldn't it throw a light if I had a code to read? I mean I'll go ahead and slap the reader in but I dont have any lights on. Just shifting weird after +65mph.
-=Gibby=-
Gibby913 is offline
post #5 of 9 Old 01-23-2015, 01:51 PM
Pierre_r
Pierre_r's Avatar
1989 XJ Cherokee
Newer might do it, but my 93 did not.
Pierre_r is offline
post #6 of 9 Old 01-28-2015, 07:35 AM Thread Starter
Gibby913
Sooooo. Did you have any guidance to give? It seemed like you had a thought.....did it drift away? lol. Still an issue, please help!
-=Gibby=-
Gibby913 is offline
post #7 of 9 Old 01-28-2015, 05:24 PM
ZeeJay1997
i was also thinking tcc solenoid but i had another question and got too busy to type it out... so yes i did drift off...
if you dont do anything but stop, does the engine choke down go dead? and if you put it neutral does it stop it from choking?
post #8 of 9 Old 01-28-2015, 11:05 PM
dan66cj5
1966 CJ5
Might be time for a rebuild.. my trans had all kinds of weird problems till it finally quit. Seals may be blown, bands worn out, clutches burnt.. Have you adjusted the bands ? My trans only had 135k when it went.
dan66cj5 is offline
post #9 of 9 Old 02-03-2015, 11:01 AM Thread Starter
Gibby913
@Zeejay No, engine doesnt choke at all. Just the tranny sometimes doesnt want to hop out of first.
@dan - just replaced all solenoids / electronics and theres no sign of damage inside case. No substantials shavings or chunks etc etc
-=Gibby=-
Gibby913 is offline
