WJ Brakes on a ZJ - The simple way - JeepForum.com
 9Likes
post #1 of 26 Old 12-06-2019, 09:20 AM Thread Starter
Fernando
Fernando's Avatar
1987 YJ Wrangler
Hello dear Forum
I have a 1997 ZJ with the 4.0 engine, 42RE and NP242
I want to improve the stopping power on it, so I am looking into the WJ brake upgrade, however, I have seen tons of threads with people cutting/welding/replacing steering parts and such. This Jeep is a daily drive and I use it to haul music gear from one gig to another, will not see mud or rocks, will not get tires bigger than 31" and if it ever sees a lift it will be just enough for the 31s to fit.
Having said this, is it possible to get the calipers, knuckles, spacers, and reuse the steering? or is it absolutely necessary to perform the steering upgrade at the same time? It does elevate costs and adds a significant amount of complication for something I don't have a problem with.
For me, it would be ideal to replace the tie rod ends, knuckles, calipers, weld the spacers to the knuckle and add the caliper spacers, and reuse my steering, however, I don't know if this is possible or not.
Will my stock rims work with the new calipers, or do I need to think about new rims as well?
All help is appreciated, thanks!
Originally Posted by JeepHammer
I don't mind writing for Fernando because he reads, and re-reads EVERY WORD!... Good to write for someone that actually READS the answer, and takes time to UNDERSTAND what comes back for an answer!
Fernando is offline
post #2 of 26 Old 12-06-2019, 09:29 AM
Timo_90xj
Timo_90xj's Avatar
You can use the stock y-link steering, but you loose one of the big improvements WJ knuckles would give you.
Some 15" steel wheels do work with the WJ brakes if they have at least 4" of backspacing. You may need to trim a bit from the caliper edges. 16" wheels work no matter if they are steel or alloy.
Fernando and Wolfeman1992 like this.
***Under construction***
Timo_90xj is offline
post #3 of 26 Old 12-06-2019, 09:46 AM
Wolfeman1992
Wolfeman1992's Avatar
1994 ZJ
What about stock wj steering could he use that?
94 ZJ 4.5" on 31s
Wolfeman1992 is offline
post #4 of 26 Old 12-06-2019, 09:46 AM Thread Starter
Fernando
Fernando's Avatar
1987 YJ Wrangler
I have the stock 16 inch rims, that's good news.
If I want to reuse the steering, it is a matter of just bolting things back together?
Fernando is offline
post #5 of 26 Old 12-06-2019, 10:01 AM
CatSplat
CatSplat's Avatar
1994 ZJ
94 ZJ 4.5" on 31s
WJ axles are wider than ZJ ones, so their steering links are all proportionally longer. I believe the adjustment range isn't large enough to reduce them down to a usable length for ZJs.
Pretty much yes. Attach your TREs to the lower steering arms on the WJ knuckles and do an alignment. TRE taper is the same on ZJ and WJ so you should have no problems there.
Fernando likes this.
1994 5.9L ZJ | IRO 5.5" CPLA | NP242 | 33" Cooper Discoverer STT Pro
The Jeep of Theseus
CatSplat is offline
post #6 of 26 Old 12-06-2019, 10:19 AM
Timo_90xj
Timo_90xj's Avatar
^- this exactly.
post #7 of 26 Old 12-06-2019, 10:29 AM
CatSplat
CatSplat's Avatar
1994 ZJ
And since it hasn't been mentioned yet, don't forget that you will need to change out your lower ball joints for WJ ones as they use a different taper than ZJ lowers.
The Jeep of Theseus
CatSplat is offline
post #8 of 26 Old 12-06-2019, 10:38 AM Thread Starter
Fernando
Fernando's Avatar
1987 YJ Wrangler
Excellent, thank you so much for the information!
Ok good, made a note. Thanks!
Fernando is offline
post #9 of 26 Old 12-06-2019, 10:45 AM
CatSplat
CatSplat's Avatar
1994 ZJ
Happy to help!
You may find it helpful to take a read through my WJ knuckle thread, there's a bunch of stuff in there with regards to steering you won't need but the fundamentals are the same. You can also ignore the ABS stuff if you don't want to bother.
The Jeep of Theseus
CatSplat is offline
post #10 of 26 Old 12-06-2019, 11:03 AM
Wolfeman1992
1994 ZJ
[QUOTE=CatSplat;40811373]WJ axles are wider than ZJ ones, so their steering links are all proportionally longer. I believe the adjustment range isn't large enough to reduce them down to a usable length for ZJs.
Has anybody actually tried though? Id imagine theres some way to make it work
94 ZJ 4.5" on 31s
post #11 of 26 Old 12-06-2019, 11:11 AM
Timo_90xj
Timo_90xj's Avatar
They won't work. You need custom length draglink and tierod.
post #12 of 26 Old 12-06-2019, 11:30 AM
Wolfeman1992
1994 ZJ
Ok stupid question what if you used zj TREs and cut down the wj draglink?
94 ZJ 4.5" on 31s
post #13 of 26 Old 12-06-2019, 11:33 AM
CatSplat
CatSplat's Avatar
1994 ZJ
I didn't physically try to install them, but I did measure them out at the junkyard and my calculations indicated they would be no bueno. You could always cut-sleeve-weld if you wanted, would save a few bucks if you don't need the strength of DOM links.
ZJ TREs are a smaller thread than the WJ ones so they won't work in a WJ tie rod.
Wolfeman1992 likes this.
The Jeep of Theseus
CatSplat is offline
post #14 of 26 Old 12-06-2019, 11:37 AM
Wolfeman1992
1994 ZJ
So it's one of those if your on a shoe string budget you can make it work but in the end you'll have just as much work as building custom crossover
94 ZJ 4.5" on 31s
post #15 of 26 Old 12-06-2019, 12:40 PM
Timo_90xj
Timo_90xj's Avatar
With a hack job you do more work and you end up with a way weaker setup as DOM tube steering links.
