Will you be stranded if your keyfob battery dies? - JeepForum.com
 15Likes
post #1 of 27 Old 07-30-2021, 01:08 AM Thread Starter
zjlockers
(or if the keyfob malfunctions in some other way)?
my vehicle: 1997 Jeep Grand Cherokee, 5.2liter, V8, 4x4
ps: because the "panic button" keeps getting pressed accidentally inside my pocket,
I have put the keyfob permanently inside the vehicle, hope that is safe? Of course the
physical key stays on my person.
zjlockers is offline
post #2 of 27 Old 07-30-2021, 01:28 AM
Timo_90xj
Timo_90xj's Avatar
As far as I know, '96-'98 US- spec. ZJs should disarm VTSS using the key in any of the doors. However, there seems to be conflicting info about this regarding the US- domestic versions.
I know my euro-spec. 5.9 ZJ (ZG) does NOT disarm the VTSS using the key in any of the locks, so if the keyfob malfunctions or battery dies the engine will only run for about two seconds and that's it.
***Under construction***
Timo_90xj is offline
post #3 of 27 Old 07-30-2021, 02:39 AM
Mark-318-IT
same for my 98 5.2 swapped to 5.9.
happened a couple of times, had to change the battery of the key fob in order to start the car again.
zjlockers likes this.
360swapped:np242swap,shift kit,BOLT ONs,ome HD coils,aussie locker,dana30hp trussed
Mark-318-IT is online now
post #4 of 27 Old 07-30-2021, 06:40 AM
Boone96ZJ
Boone96ZJ's Avatar
the (US spec) Jeep will absolutely run without the FOB at all. 96-98 are not chip keys and there is not a chip in the fob either. as long as the correct key is in the ignition it will crank and run all day.
96 5.2 242 3" 32x11.5
https://www.jeepforum.com/forum/f13/1996-grand-cherokee-laredo-5-2-a-2570290/
Boone96ZJ is offline
post #5 of 27 Old 07-30-2021, 08:41 AM
kg6mov
Hears the voices
kg6mov's Avatar
Yup, that ^^
From the factory, the key in any door lock will disarm the security system for the NA market. Fob not required for anything but convenience.
kg6mov is offline
post #6 of 27 Old 07-30-2021, 08:49 AM
Mr. Puddles
In theory. lol Mine will only disarm from the back hatch.
Follow the build!
2002 Dakota aka Winnie aka Mad Max
1996 Grand Cherokee aka Puddles aka Pikey Life
The 4.0 is dumb old tractor motor, itís too stupid to know itís supposed to die.
Mr. Puddles is offline
post #7 of 27 Old 07-30-2021, 09:21 AM
wingless
wingless's Avatar
1994 ZJ
The key activated alarm disarm switches don't always work properly. Fortunately there are three switches, improving the odds of success.
wingless is online now
post #8 of 27 Old 07-30-2021, 09:41 AM
kg6mov
Hears the voices
kg6mov's Avatar
I said from the factory for a reason. The switches break from abuse and so a lot of the used ZJís out there only have one door left that works.
You could of course fix that . . . but parts arenít really available.
kg6mov is offline
post #9 of 27 Old 07-30-2021, 02:58 PM Thread Starter
zjlockers
So, I am putting a bunch of extra CR2016 batteries in the vehicle with the keyfob (and a small screwdriver for doing a battery swap).
Hopefully that will take care of me, fingers crossed.
Kinda makes me miss the simpler old days.
I wonder if the dealer can just simply DISABLE the alarm/security/keyfob junk.....
post #10 of 27 Old 07-30-2021, 09:41 PM
Mr. Puddles
I want to say I remember reading the security module is behind the glove box and it should just unplug
Follow the build!
post #11 of 27 Old 07-30-2021, 09:53 PM
kg6mov
Hears the voices
kg6mov's Avatar
True for first gen, second gen it's integrated into the pcm.
kg6mov is offline
post #12 of 27 Old 07-30-2021, 10:12 PM
Mr. Puddles
Figures
Id suggest making life easy on yourself. Arm the system and go around an unlock doors and see which if any doors disarm the system. If you can find at least 1 then I wouldnt worry too much. I have a fob but I dont carry it 1) because its the only one I have and its the original and 2) because I cant get it to save seat and mirror setting so it keeps messing them up and when the adjustment gears on the seat a spotty to begin with getting it back where you want can be.....troublesome.
Follow the build!
post #13 of 27 Old 07-30-2021, 10:30 PM
PolkaPower
PolkaPower's Avatar
I don't use my fob at all.
Sent from my iPhone using Tapatalk
PolkaPower is offline
post #14 of 27 Old 07-31-2021, 02:44 AM Thread Starter
zjlockers
I have never even owned a fob until now; so, it's all brand-new to me.
I did notice that one time I left the rear-window latch unlatched, and it started
flashing that red-light near the AC-air-intake (top of dashboard), and when I
inserted the key, it started honking.....
I pressed the 'panic' button to try to get it to stop, and it finally stopped honking.
Without the fob in the console, would I have been able to make the honking stop (and start
the engine)?
post #15 of 27 Old 07-31-2021, 03:05 AM
PolkaPower
PolkaPower's Avatar
the engine)?
It usually turns off the alarm with one of the door/hatch locks. If not you have to pull the horn relay so your neighbors won't hate you.
