Will an AW4 bolt into a 42re spot no problem or/ - JeepForum.com
post #1 of 8 Old 01-29-2009, 09:58 AM Thread Starter
animalv3
Hi i have a beautiful 42re sitting in my 98 ZJ and its beggining to slip here and there, my friend has a aw4 out of a 88 XJ sitting and is in mint condition just about. I was wondering if anyone had any info regarding both of these transmissions which both had 242's bolted to it. Hoping for the best any info will help
animalv3 is offline
post #2 of 8 Old 01-29-2009, 10:04 AM
allenjp
Guest
They were both used for the same engine and t-case...seems like you should be good to go. You should just make sure that all the clearances would work. Don't take my word for it though. I understand why you would want that AW4 tranny, I had a '93 XJ with that tranny and it is a BEAST.
allenjp is offline
post #3 of 8 Old 01-29-2009, 10:12 AM
ratmonkey
R.I.P.
ratmonkey's Avatar
you'll get a check engine light, no trans computer.
ratmonkey is offline
post #4 of 8 Old 01-29-2009, 10:18 AM
allenjp
Guest
Good point. IDK how it is in MA, but in CA you won't pass smog with a CEL on...
allenjp is offline
post #5 of 8 Old 01-29-2009, 10:18 AM Thread Starter
animalv3
now will the computer read it? am i splicing connections and such or will it be plug and play? i dont mind check engine if it drives fine hah
animalv3 is offline
post #6 of 8 Old 01-29-2009, 10:21 AM Thread Starter
animalv3
Like i said hoping it will be a bolt in and call it a day just worried about connections really
animalv3 is offline
post #7 of 8 Old 01-29-2009, 10:35 AM
ratmonkey
R.I.P.
ratmonkey's Avatar
ok, since you don't know how to use the search function.
https://www.jeepforum.com/forum/showt...light=aw4+swap
post #8 of 8 Old 01-29-2009, 11:33 AM Thread Starter
animalv3
forgot to mention im mildly retarded and just went straight to post then search thanks for the help guy
animalv3 is offline
42RE problem dtaz3 ZJ Grand Cherokee Forum 2 01-24-2010 09:07 PM
1996 Grand Cherokee 42re Tranny problem sixtires58 ZJ Grand Cherokee Forum 13 12-22-2009 09:42 PM
42RE transmission pan bolt torque? Rubaiyat ZJ Grand Cherokee Forum 4 08-20-2009 07:43 AM
42re trans problem JeepElite ZJ Grand Cherokee Forum 11 04-06-2008 12:23 AM
42RE overdrive problem 98 GC 4.0L stufor ZJ Grand Cherokee Forum 6 09-14-2006 03:11 PM
