wife didn't check oil for a month while i was gone. - JeepForum.com
 13Likes
post #1 of 17 Old 05-15-2019, 04:24 PM Thread Starter
TheRaccoon
1994 ZJ
So my wife forgot to check the oil for a month while I was out of town.
I came back did my usual check of all fluids which I do weekly and I had no oil....
I discovered I have a rear main seal leak and immediately put 5 quarts oil and 1-quart magic mystery oil in and it seems a lot better. no knocking as far as I can tell but my question is this
Is there a way to tell if things are damaged beyond repair?
TheRaccoon is offline
post #2 of 17 Old 05-15-2019, 04:59 PM
xtrattitude4u
Only oil pressure and noises afaik.
If you see less pressure or new noises then you got some damage.
You could also do a compression test.
Sent from my Pixel XL using Tapatalk
dezratnv likes this.
xtrattitude4u is offline
post #3 of 17 Old 05-15-2019, 05:34 PM Thread Starter
TheRaccoon
1994 ZJ
thanks, ill have a test ran tommorrow
post #4 of 17 Old 05-15-2019, 07:28 PM
GChief
GChief's Avatar
Oil analyst will also let you know. I do them on every new to me used vehicle I get. Well spent $20-25.
Thanks Rob
GChief is offline
post #5 of 17 Old 05-15-2019, 08:18 PM
downs
downs's Avatar
1995 XJ Cherokee
I'd pull an oil analysis on it as well as do a compression test.
GChief likes this.
1995 Jeep Cherokee Country 4X4 Stock
AW4/NP231/C8.25/D30/"UpCounty" suspension
downs is offline
post #6 of 17 Old 05-15-2019, 10:44 PM
rep-tile
Cash 4 clunkers survivor
rep-tile's Avatar
It's a 4L. It can take it.
My question is how do you get the wife to check the oil? Mine doesn't even check the fuel gauge.
Ross, trojanbrutha, jtec and 2 others like this.
04 WJ 4.0 - Avital 4103, DB-ALL
91 XJ 4.0 - Avital 4103, Stage-2 aFe intake system, BBK high flow Throttle Body, 703s injectors, Jones Exhaust A3518M-5
rep-tile is offline
post #7 of 17 Old 05-15-2019, 10:55 PM
PolkaPower
PolkaPower's Avatar
More like you neglected to do maintenance on your vehicle and then bamed your wife.
Sent from my BND-L24 using Tapatalk
blueseasons and Kahlis like this.
PolkaPower is offline
post #8 of 17 Old 05-16-2019, 04:47 AM
V8GCZJ
Ask the wife if she oil light came on ever? Might want to drain the existing oil and see if you see any obvious damage. Metallic particles/pieces etc... Since you added oil it may have diluted it.
V8GCZJ is offline
post #9 of 17 Old 05-16-2019, 05:12 AM
RubiconFreedom
2017 JK Wrangler
I'd say this was a ploy to get rid of that jeep and get her into something new.
GChief likes this.
RubiconFreedom is offline
post #10 of 17 Old 05-16-2019, 07:39 AM
jtec
jtec's Avatar
2014 JK Wrangler
5+ quarts in how many miles? Normal is @1k miles per month, so your leaking 5quarts in a 1k miles??
FIX THE ISSUE.
Might want to check PCV/CCV system.
jtec is offline
post #11 of 17 Old 05-16-2019, 07:45 AM
StPaul59
That's not a leak, that's a waterfall.
That's 60 quarts a year..
Mark-318-IT and Clicker01 like this.
StPaul59 is offline
post #12 of 17 Old 05-16-2019, 07:47 AM
zjosh93
How far/long was it driven low on oil?
6 quarts of oil in a month is a huge oil leak. It would usually leave a huge puddle on the driveway. Even if it was only leaking while the engine was running it would still be pretty obvious. Worth checking out the oil pressure sensor. I've had them fail so that they leak pretty badly.
On the 4.0 you can pull the oil pan and check the main and rod bearings pretty easily. Worth a look if was really 6 quarts low on oil, i.e. no oil.
Compression test is probably not going to tell you anything. Bearings will melt and fail long before the lack of cylinder wall lubrication causes ring seal to suffer. And you'll go deaf from the knocking before the added bearing clearance changes the compression enough to matter.
Oil pressure, new knocking or tapping sounds, visual check of the bearings. That's what I'd do and in that order. Tricky though because you can ruin one rod bearing and still have good oil pressure while the bad bearing ruins the rod and crank. And let's be honest the 4.0 isn't a quiet motor so a faint new tapping could be hard to hear. You'd want to listen for a knock or tap that goes away or comes back when you hit or let off the throttle.
zjosh93 is offline
post #13 of 17 Old 05-17-2019, 05:55 PM Thread Starter
TheRaccoon
1994 ZJ
I’m not blamin her, it happens we’ve had a leak for awhile but I’d been topping it off until I had the money to fix. But it was indeed a waterfall coming from main seal and up out of distributor cap.
I’m not sure what caused the small leak to accelerate but it’s fixed now.
post #14 of 17 Old 05-17-2019, 06:07 PM
HighLonesome
HighLonesome's Avatar
Poor wifey. I do hold mine accountable for reporting noises and changes in operation. It's her ZJ anyways.
HighLonesome is offline
post #15 of 17 Old 05-17-2019, 08:39 PM
GOLDWING
GOLDWING's Avatar
My better half is great at letting me know about noises, smells and odd ZJ behavior. Last week she mentioned a pulse under hard braking and today she got new Raybestos rotors up front ($45 shipped RA) and I am happy to report that the problem has been dealt with to her satisfaction.
GW
Ross likes this.
"The Dude Abides"
GOLDWING is offline
12 Things You Can Do When Your ZJ Stalls ZeeJay1997 ZJ Grand Cherokee Forum 448 05-28-2019 07:14 PM
HELP! Massive oil leak 2.5 YJ Malenlie Engines & Drivetrain 2 03-16-2019 12:51 AM
High Oil Pressure and Rough Idle Zyurazek YJ Wrangler Technical Forum 28 10-10-2018 08:17 PM
Trying to resolve occasional stalls & recent oil pressure warning gcstump WJ Grand Cherokee Forum 32 05-14-2018 10:53 AM
Oil Leaking flyby71 TJ Wrangler Technical Forum 25 12-31-2017 01:58 PM
