Why my ZJ won't see redline while acceleration? - JeepForum.com
post #1 of 9 Old 06-30-2020, 12:12 PM Thread Starter
delmanciomio
Hello,
My 97 5.2 ZJ revs beyond 5000rpm in Neutral but when i try to accelerate wide open throttle it shifts about 3500rpm and this will not give good performance. Why this is happening ? What regulates rpms before shifting?
Thank you
delmanciomio is offline
post #2 of 9 Old 06-30-2020, 12:22 PM
Timo_90xj
Timo_90xj's Avatar
Adjust your throttle valve cable. If it is too loose, transmission will shift at way too low rpms. Even with a properly adjusted TV cable, V8 shifts at around 4750-5000rpms, and I'm pretty sure I6 does the same.
If you want it closer to redline, use manual shifting. Installing a shift correction kit helps, installing Sonnax ZIP- kit improves shift behavior and addresses various other valve body issues.
There are other possible causes, but it's easy to start with the TV cable.
My niner redlines at 6000rpms, WOT upshift at around 5850. Not stock, has a custom tune. Magnum sounds pretty damn good at 6k
***Under construction***
Timo_90xj is offline
post #3 of 9 Old 06-30-2020, 02:09 PM
zjosh93
My 93 would always shift at the redline. I think I just had the TV cable a touch on the tight side of the OEM adjustment. I think it shifts a little lower with the new transmission, but my sister is the primary driver now, and she doesn't drive like me.
zjosh93 is offline
post #4 of 9 Old 07-01-2020, 04:25 AM Thread Starter
delmanciomio
Yes its loose, can you tell me how can i make it tighter, i am new to car and i want to learn from you guys
post #5 of 9 Old 07-01-2020, 05:19 AM
Zilliver
Remove the white clip holding it, tighten it so it will start to move as soon as the throttle valve is moving. Then go for a test drive, if needed adjust it again, but do it in small steps.
Dont make it too tight - no up shifts
Dont make it too loose - very quick shifts all the time in low rpm.
98 Grand Cherokee 5.9 - daily
95 Grand Cherokee 5.2 - offroad
Zilliver is offline
post #6 of 9 Old 07-01-2020, 07:29 AM
Timo_90xj
Timo_90xj's Avatar
Basically the throttle valve cable should be tight with the throttle pedal pushed all the way to the floor.
To adjust, CAREFULLY (!!!) remove the TV cable endclip (ball socket) from the throttle linkage ball. Then have a helper push the throttle all the way down; adjust TV cable length so that cable pulled tight the ball socket is centered on the linkage ball. Release throttle and re-install cable.
FSM instructs adjusting the TV cable with the throttle plate closed and aligning the cable end socket to within 1mm (0.040") of the throttle linkage ball stud.
Both methods work, but I prefer adjusting @ WOT to ensure highest possible line pressure at WOT upshifts.
Whichever method you use, after adjusting go for a test drive - if it upshifts at full throttle ~5000rpms you're good to go; if it doesn't shift loosen the adjustment a little. If it upshifts a way too low RPMs, tighten the adjustment a little.
Your aim is to have the cable as tight as possible with the tranny still upshifting @ WOT.
If valve body/ transmission has internal leakage issues or sticky valves, tired pump that doesn't provide high enough pressure, TV cable adjustment won't necessarily help at all.
If TV cable adjustment doesn't make a difference, I'd highly suggest doing pressure tests per FSM.
post #7 of 9 Old 07-02-2020, 05:56 PM
norconick
yes like everyone else has said you have to be delicate. The little white U clip keeps the whole adjuster locked together and its probably quite brittle by now. The first time I adjusted mine I did like half centimeter increments and that was way too much. Seriously I'd go like a millimeter at a time once you've got it so it'll shift between 4500 and 5000 like it should. You can feel the difference in shift harshness under light throttle with 1 mm adjustments.
I can make you a little video if you haven't already found one
'98 ZJ 5.9 Limited -- 284k kms
'08 Escape Hybrid AWD -- 532k kms
'04 VW Jetta TDI -- 408k kms
norconick is offline
post #8 of 9 Old 07-02-2020, 05:58 PM
norconick
Do you have a cam in it? With the stock cam and stock intake manifold the horsepower drops off fast after about 4000 rpm on mine
post #9 of 9 Old 07-02-2020, 10:18 PM
Timo_90xj
Timo_90xj's Avatar
Cam, heads, intake manifold, throttle body & exhaust have all been upgraded along with a custom tune from Flyin' Ryan.
...and yes, both the 5.2 and 5.9 as stock don't really go anywhere after about 4500rpms especially with a stock PCM flash.
