white smoke from engine after swapping out radiator, waterpump and thermo - JeepForum.com
post #1 of 9 Old 01-07-2012, 12:46 PM Thread Starter
specspecimen
1997 XJ Cherokee
I am new here and all these forums have been super helpful in the past so hopefully I can find a solution to this problem quick because I start class Monday and am a poor college student. Typical story but whatever.
Anyway I replaced my radiator, water pump and thermostat yesterday on my 1997 Jeep Grand Cherokee 4.0 to stop a leak that was happening. Filled my radiator back up and now whenever the car runs white smoke comes from the engine. I do not understand why but if there is any solution anyone knows could they please let me know what it is and how I might go about fixing it!
You all are awesome
specspecimen is offline
post #2 of 9 Old 01-07-2012, 12:48 PM
PolkaPower
PolkaPower's Avatar
Did you spill fluids on the exhaust and it's burning it off?
PolkaPower is offline
post #3 of 9 Old 01-07-2012, 12:49 PM Thread Starter
specspecimen
1997 XJ Cherokee
the smoke is not coming out of the tailpipe, rather it is coming off the engine itself.
post #4 of 9 Old 01-07-2012, 12:52 PM
PolkaPower
PolkaPower's Avatar
Like I said you could have spilled some fluid on the headers or block and it's heating up and burning off. When I fixed my trans some fluid dripped down on the header pipes and burned off white. I was alarmed at first until I went under the jeep while it was running and saw where the smoke was coming from.
post #5 of 9 Old 01-07-2012, 12:53 PM
RED-85-Z51
Coolant takes a while to evaporate off, as it doesnt just flash to steam @ 212* like water...if you got coolant on the engine, its going to take a bit to go away.
RED-85-Z51 is offline
post #6 of 9 Old 01-07-2012, 12:53 PM
caligiuri87
1994 ZJ
thats what he means lol if u spill it take sa bit for it to burn of. when u start the engine let the rad cap of and see if air comes out if not jsut close it and keep an eye on the temp gauge also grab a flashlight and look around maybe its leaking outta hose u didnt clamp good. i think its just burning off can take a bit. i had that too. keep an eye on the temp and keep an eye o nthe coolant in the first few days
Shaky.......shaky shaky shakyyyyyyy.....crack boom pow @%^@%@%@[email protected]#$^%&*(^&&%[email protected]!!!!!!
Happy to be a JEEP owner
caligiuri87 is offline
post #7 of 9 Old 01-07-2012, 12:58 PM Thread Starter
specspecimen
1997 XJ Cherokee
thank you all so much! i really appreciate it. i'm going to take a look at it and let it run right now and we'll see how that goes
post #8 of 9 Old 01-07-2012, 01:00 PM
Foundrydude
Let it warm up and dry out, should be no wet areas after 10 or 15 minutes
Foundrydude is offline
post #9 of 9 Old 01-07-2012, 01:09 PM
PolkaPower
PolkaPower's Avatar
That's what she said!
radiator , smoke , thermostat , water pump , white
Replacing thermostat, waterpump, and radiator ZJPunk98 ZJ Grand Cherokee Forum 17 06-06-2010 01:05 PM
Low Oil, white smoke JamesLouis ZJ Grand Cherokee Forum 9 10-15-2009 12:19 PM
4.7 white smoke on startup then goes away UNDERDAWG ZJ Grand Cherokee Forum 9 04-25-2009 08:54 PM
White Smoke BRayf78 ZJ Grand Cherokee Forum 22 04-23-2008 12:14 PM
