Where to find Miller Tool 7932 7603 7604 - JeepForum.com
post #1 of 10 Old 08-02-2020, 07:37 AM Thread Starter
KiloWatts
KiloWatts's Avatar
I'm looking for the Miller Tool combo kit that works to remove the UCA on the axle side. There is one on eBay but it's around $360, but that price doesn't seem right for a bolt and a couple pieces of metal. If there are other tools (aside from a ball joint press) for this job I'd be interested. Or if anyone here wants to sell me theirs
Sent from my Pixel 3 using Tapatalk
1996 4.0 L6 RWD
KiloWatts is offline
post #2 of 10 Old 08-02-2020, 07:43 AM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
To remove axle side bushings, use a hole saw to remove the most of the rubber, or use a torch and burn it out. Chisel out the shell. You can use a hack saw blade to slit the shell if necessary.
Press in the new bushing with a ball joint press. On the passenger side you might need a shim to stop the open side of mount from flexing.
“When the people find that they can vote themselves money, that will herald the end of the Republic.”
- Benjamin Franklin
CJ7-Tim is offline
post #3 of 10 Old 08-02-2020, 07:53 AM Thread Starter
KiloWatts
KiloWatts's Avatar
Hey thanks - this tool is for removing the entire arm from the axle, not just the bushing. I don't know if I'll ever get into bushing replacement, as I've always just purchased the whole arm.
1996 4.0 L6 RWD
post #4 of 10 Old 08-02-2020, 07:59 AM Thread Starter
KiloWatts
KiloWatts's Avatar
Right, I forgot tbe axel side bushing is separate. I don't really want to go with the brute force method (hole saw + torch) but if I can do it without losing an eyeball then maybe I'm game.
1996 4.0 L6 RWD
post #5 of 10 Old 08-02-2020, 08:11 AM
CJ7-Tim
CJ7-Tim's Avatar
The control arm assemblies unbolt and require no tools other than maybe a pry bar or hammer to remove.
- Benjamin Franklin
CJ7-Tim is offline
post #6 of 10 Old 08-02-2020, 09:27 AM
Timo_90xj
Timo_90xj's Avatar
Front axle UCA bushings are a bit of a pain due to space limitations, but it's all doable with basic garage tools. Do what CJ7-Tim suggested: hole saw or torch to remove the rubber bushing, and chisel out the outer shell. I used a hole saw with a couple extra- large heavy duty washers and all- thread + nuts to press in the new bushings, happened to have a matching size for the bushing
I honestly see no point in paying 300-400$ for a tool kit that you most likely use no more than a couple of times in your entire life. At that point it makes more sense to take the Jeep to a shop and have them replace the bushings if you don't want to try it yourself.
***Under construction***
Timo_90xj is offline
post #7 of 10 Old 08-02-2020, 01:41 PM
zjosh93
I made the tool out of exhaust pipe and steel scrap I had in my garage. The only thing I bought was a piece of 3/8" Grade 8 threaded rod since some people reported breaking regular threaded rod.
zjosh93 is online now
post #8 of 10 Old 08-02-2020, 04:54 PM
jeepjeepster
Not sure why you would need any sort of special tool besides a ratchet, some sockets, and a torx bit. Just took mine out a couple of months ago.
1994 ZJ-I6 w/270,000 mi
1998 ZJ 5.9 w/66,000 mi Slate Black
2004 KJ w/108,000 mi
jeepjeepster is offline
post #9 of 10 Old 08-03-2020, 02:45 AM
Timo_90xj
Timo_90xj's Avatar
Upper control arm replacement requires the tools you mentioned, but you're not replacing the bushings with them
post #10 of 10 Old 08-03-2020, 05:40 PM
jeepjeepster
Ahh, I saw post 3 where he said wasnt removing the bushing and skipped over post #4... O well...
