What's the secret? - JeepForum.com
 3Likes
  • 1 Post By Titnado1
  • 1 Post By wingless
post #1 of 9 Old 09-19-2021, 02:47 PM Thread Starter
Titnado1
What's the secret?
Passenger side top exhaust bolt on the collector? How do you guys get that bolt back on? Getting it off was easy with some long extensions but I cant for the life of me get my hand in there to hold the nut in place... so what's the secret to it?
If you can drive it, fly it, or bang it.... rent it.
Titnado1 is offline
post #2 of 9 Old 09-19-2021, 03:16 PM
GOLDWING
GOLDWING's Avatar
I am not familiar with your particular situation, but I have welded heavy #9 wire to nuts so they could be manipulated to where I could start the bolt into the threads. I have also built "flag nuts" with a tab of steel like on the axle side of the front trackbar nut.
A gas shielded Mig welder like my Hobart 140 Handler is worth owning when you own a 20+ year old Jeep. A friend who owns one will do in a pinch.
"The Dude Abides"
"Your axles are going to turn into spaghetti noodles."
Polka Power 1/3/2021
GOLDWING is offline
post #3 of 9 Old 09-19-2021, 05:16 PM
wingless
wingless's Avatar
1994 ZJ
This reply has links to my exhaust removal / replacement.
This reply has links for replacing the passenger side manifold fasteners.
wingless is offline
post #4 of 9 Old 09-19-2021, 05:17 PM Thread Starter
Titnado1
I do own one and also a lincoln power mig 300 and you might be right that might be the only way to get one up there
GOLDWING likes this.
Titnado1 is offline
post #5 of 9 Old 09-19-2021, 05:29 PM Thread Starter
Titnado1
thanks wingless i can see alot of foul words coming out on that last bolt.
wingless likes this.
Titnado1 is offline
post #6 of 9 Old 09-19-2021, 05:50 PM
yjsaabman
1930 CJ2
Nut on top or bottom? Either way you can use a piece of painters tape to secure the nut in the box end of a wrench to help get/hold it in position to start the hardware.
Weren't the original nuts (or nuts originally) secured by a tin clip that held the nut onto the manifold flange? I know they don't normally last long, just trying to remember.
Sent from my SM-G970U using Tapatalk
yjsaabman is offline
post #7 of 9 Old 09-19-2021, 06:05 PM
wingless
wingless's Avatar
1994 ZJ
Yes, I cheat and use an index card with all the profanity words so I donít skip any in the heat of the moment.
Nuts, hardware and part numbers all shown in my links.
Nuts on bottom.
wingless is offline
post #8 of 9 Old 09-21-2021, 04:48 AM
V8GCZJ
Weld two nut's together, It will keep the nut from spinning when you turn the bolt.
V8GCZJ is offline
post #9 of 9 Old 09-21-2021, 05:50 PM Thread Starter
Titnado1
Thanks for all the replies I ended up getting it but did lose a socket im there somewhere. looked everywhere for it.
Titnado1 is offline
