What rear end do I have - JeepForum.com
post #1 of 7 Old 08-17-2019, 08:31 PM Thread Starter
jmcclurg84
I got a 1998 Jeep Grand Cherokee awd 5.2l there is no tag on the rear end. How can I tell what diff and gear ratio I have?
Thanks
jmcclurg84 is offline
post #2 of 7 Old 08-17-2019, 10:49 PM
nickfast
It came with a D44A w/3.73's.
Whether that's what it still has, I have no way of knowing.
nickfast is offline
post #3 of 7 Old 08-17-2019, 11:42 PM
222Doc
222Doc's Avatar
do a tire <to> drive shaft rotation count and do the math=rather simple.
222Doc is offline
post #4 of 7 Old 08-18-2019, 12:09 AM
kg6mov
Hears the voices
kg6mov's Avatar
44a with 3.73's was factory as stated. Almost all V8 are 3.73, and the probability of a 3.55 unicorn in a 98 is 0.
kg6mov is offline
post #5 of 7 Old 08-18-2019, 12:47 AM
IMMORTEN
IMMORTEN's Avatar
Picture?
Maybe this will help:
https://www.extremeterrain.com/wrang...ification.html
Sent from my iPhone using Tapatalk
IMMORTEN is offline
post #6 of 7 Old 08-18-2019, 11:51 AM Thread Starter
jmcclurg84
Thanks guys. Definitely a 44. I will be pulling the cover off and counting teeth shortly just to confirm the ratio but I wanted to figure out what is was so I can look into parts.
post #7 of 7 Old 08-18-2019, 12:41 PM
Timo_90xj
Timo_90xj's Avatar
Do remember that the D44HD (also called D44a due to the aluminum center section) doesn't really share any parts with the standard D44.
R&P tooth counts should be stamped on the side of ring gear, something like 41 11 = 3.73
***Under construction***
Timo_90xj is online now
