What to lube rear main seal with on 4.0 - JeepForum.com
post #1 of 8 Old 01-28-2010, 10:55 AM Thread Starter
JAC1502
replacing rear main seal tonight and seems cake except I have read several different coatings for the upper block seal
EX:
hand soap
oil
oil one bottom lip RTV on upper to block portion
nothing at all
ETC????
I had only planned on using a small amount of rvt where the seals meet and at the upper block corners of the oil pan. Is this correct?
My jeep is an 04 so I also have the bearing cap truss / girdle. does that have a spefic torque? I read 80 pounds for the bearing cap.
What about the oil pan bolts
any tips from experts are always welcome!
#1 1997 Jeep TJ HEMI, 6" lift springs, 2" body lift, semi long control arms front and rear, Adjustable front and rear track bars, Slip-Yoke elim, 8.8 locked, 10,000 winch, Tube bumpers and rocker guards, Light bar, Custom swing away tire carrier, CAI, Electric cooling fans, Custom exhaust, Mickey T 35*14.5 on 15*12 wheels #2 2004 Grand Cherokee SE 4.0L, header, full exhaust, CAI, Bored TB, Clarion 10, RC X series 4" + 1, teflon wheels 17s, roof rack, winch, etc.
JAC1502 is offline
post #2 of 8 Old 02-07-2010, 07:38 PM
autoposer
Just finished mine on a 2000 XJ (2001 seal type). I used liquid soap on the top seal and was able to get it in without too much trouble. I also have the truss /girdle and 80 foot pounds like the bearing cap seemed like to much to me so I did less. I believe the oil pan bolts are 11 foot pounds.
autoposer is offline
post #3 of 8 Old 02-07-2010, 07:58 PM Thread Starter
JAC1502
I ended up breaking one of the truss / girdle studs according to what I read its suppose to be only 35 foot pounds. Have you driven much since you replaced the seal? I think mine is still leaking because it has not fully expanded. I have probably only put 30 miles on it. I don't see how I could have done it any better! Where did you get your seal? I have a feeling if my seal is still leaking its from a cheap seal.
JAC1502 is offline
post #4 of 8 Old 02-08-2010, 08:42 PM
autoposer
Got mine at Napa Auto Parts for $35. I ended need two of them because I destroyed the first one getting it in :-) I've let it idle for 35 minutes or so and have put about 4 miles on it so far with no leaks. As its not my primary vehicle it wont see a lot of action until summer. I have seen several post of people who noticed the head gasket was leaking after main rear seal replacement (mine was bad).
post #5 of 8 Old 02-08-2010, 08:47 PM Thread Starter
JAC1502
hmmm looks like I'll have to buy some dye. I spray painted my inspection plate silver to get a better ideal of where the oil was leaking but it didn't help
JAC1502 is offline
post #6 of 8 Old 03-02-2010, 09:54 PM
autoposer
Are you still seeing an oil leak from the rear main seal? I've now put about 100 miles on my Jeep since the seal change and have seen a small amount of fresh oil on the flywheel inspection cover.
post #7 of 8 Old 03-03-2010, 04:22 AM Thread Starter
JAC1502
I was getting some also but I have not been parking in the garage so not sure. I am running mobil synthetic 5w30 so i plan on a heavy oil next change. I thought my replacement job went well, but i didnt get the seal from the dealer so that could be the problem. I have read that is a must.
JAC1502 is offline
post #8 of 8 Old 03-04-2010, 01:48 PM
iluvtruenos
Your favorite personal lubricant.
My Jeep is a chick magnet with reverse polarity.
2000 WJ, 4.5l, AX15, 242 D60/14b, 5.5" lift front, 7.5" rear. Ford Expedition rear coils, Ram 350 shocks, JKS, IRO Long Arms, cool Badlands flag thingy.
1987 XJ - Gone but not forgotten
iluvtruenos is offline
Rear Main Seal? ZeJokee ZJ Grand Cherokee Forum 11 10-23-2009 11:49 AM
RTV on rear main seal drespecki ZJ Grand Cherokee Forum 5 12-17-2008 02:24 PM
Rear Main seal hrjaw ZJ Grand Cherokee Forum 8 01-04-2008 07:20 AM
Rear main seal on V8... KJK ZJ Grand Cherokee Forum 8 02-02-2007 01:22 PM
rear main seal Rizzosd ZJ Grand Cherokee Forum 5 10-06-2006 10:29 PM
